Question about Logitech LX5 Cordless Optical Mouse
Mouse not working properly
I downloaded the CD that came with my mouse, but the mouse did not work. I managed to go through the "Start" menu and get to "Connectivity" menu. Once I reset the mouse, it started working. Once computer was turned back "On" the next day, the mouse failed to work again. Any suggestions?
  • 2 more comments
  • John Rocky Jan 01, 2008
    I wound up taking the green mouse fitting off the mouse cord and plug it directly into the USB port, eventhough I have a PC. This seemed to work
  • floro Feb 07, 2008
    i'm also experiencing problem with my mouse, at first boot, i need to dismount my mouse first for a few seconds to start my pc, otherswise it seems to be hangin' up during booting and really won't continue booting unless mouse is dismounted. I tried it with the usb mouse but still i encountered the same problem.. is this a bios problem? any comments or idea?
  • bedbull Feb 27, 2008
    brand new and mouse not working now
  • Anonymous Feb 19, 2009
    mouse is some times detected by pc and working properly.And sometimes not working properly.It is optical mouse.plz advice me.
    Sniper:
  • 56 Answers
Go to the BIOS and make sure to enable the mouse/keyboard usb connectivity
Posted on Dec 29, 2007
P1g41u motherboard keyboard and mouse not working
make sure the batteries are inserted correctly and have charge if applicable
usually located on the underside of the mouse there might be small plastic sticker with a phillips head screw under it rub your fingernail over the top to see if it has a screw
or make sure the usb device is properly inserted for wireless
the usb or Ps2 connection are secure with a dust free connection
or it might be the usb for wireless mouse or lead connecting to the usb port or even a faulty mouse
if this does not fix the problem
restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode
click start control panel administrative tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver rollback driver or uninstall also
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 arrows >> then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
hope this helps
http://www.microsoft.com/hardware/download/download.aspx?category=MK
complete range of drivers
Aug 10, 2012 | Computers & Internet
Mouse cursor jumping problem, how to fix it?
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
1.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
2.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
3.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
Aug 11, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Mouse not responding
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
May 18, 2010 | Logitech Webcam
Mouse Problem- Not Working
i should reinstal his driver just to make sure is working properly,you can check in start-my computer-rightclick manage -device manager- usb then click on action button and Scan for hardware changes.
Dec 10, 2009 | Microsoft Comfort Optical Mouse 3000...
Keyboard and mouse problem
download malawarebytes and upadate it before running,now if it does not work download the generic synaptics aplication from manufacturers website
Sep 01, 2009 | HP Pavilion dv2718us Notebook
Frozen mouse with a touch pad laptop computer
Check your drivers. Go into the device manager (start>control panel>system>hardware>device manager>human interface device) . If it shows a big yellow question mark, than it is a driver problem.
I would suggest that you either install or download the latest drivers for the mouse, and you can do this even without checking for a hardware conflict as stated above.
You can also access the control panel and trouble shoot your mouse through the mouse icon.
Even sometimes this may not work.....
I had an IBM brand optical mouse that continually plague me with problems until I gave it away with a computer that I built. The person who has it is still have occasionally issues with the mouse even with the proper drivers installed. I believe that it is a connection issue because sometimes the mouse will start working when you jiggle the male USB connection.
Oct 14, 2008 | HP Pavilion Media Center a1330n - AMD...
Dell latitude 820 mouse driver
Whne you double click on the mouse in device manager, does it say "device not configured" or "unable to start this device". If it says "unable to start this device" try the mouse on a different computer to make sure it works properly. If it does then you probally have a software driver problem. Try contacting the mouse manufacturer or see if you can down load drivers from their site.
Jul 24, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Take a pencil eraser to the contacts so that it will make a good connection.
Johnlgrn
Dec 29, 2007 | Computers & Internet
Mouse trouble
To fix this problem, first uninstall your mouse in your device manager. After this, use the mouse's install CD to reinstall the driver. If you do not have a CD, or it does not require a CD, windows may already have the driver pre loaded and can take care of it. If not, you can goto the mouse manufacturers web site and download the driver from there.
Dec 05, 2007 | Dynex DX-WOM20 Mouse
Logitech LX5 Cordless Optical Mouse Logo
119 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
