Question about Car Audio & Video
Stero wiring
Wondering how do i get the cable that is meant to go from the car battery into the boot of my car into the car itself so its not showing on the outside its a 2001 ford fiesta i've been tryin since boxing day now an cant seem to do it
  • 4 Answers
Probably you would be best off drilling a hole into you car wherever theres more space, depending on the gauge of the wire you should make the hole size. i would recomend drilling it above your pedals where its not visible and then passing it through the side clips or under your rug
Posted on Jan 04, 2008
Tuner on stero works fine, but will not play CD or USB do not produce sound. When CD or USB is in use, the displays shows that the cd or usb is playing. But no sound comes out of the speakers. I returned...
It sounds like you have some wiring issues, moreso issues with your speaker wiring, or your speakers. I would first test the speakers, 1 by 1 using a double A, or AA 1.5v battery. Each speaker wire pair should be tested by attaching 1 wire to the negative side of the batter, and momentarily making contact with the other wire to the positive side of the battery. A low popping/scratching sound should be heard from each speaker. If not, replace each defective unit. Also, double check your wires to ensure they are not damaged.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 19, 2011 | Sony CDX-GT550UI
I have aan Acer Aspire 5315 which is 2 and a half years old. The battery died so I plugged in the cable in the usual way and nothing happened no lights came on. I assumed the powercable needed replacing...
The power ports are generally the problem. If you wiggle the wire and get contact that is almost sure that is it. The Internet has folks that will fix this problem.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/ shows how to repair it yourself.
Aug 03, 2010 | Acer Aspire 5315 Notebook
Car battery always going flat!
just a spare wire i think for a different model with the same wiring loom ,try a new alternator and not a scrappy yard one
May 16, 2010 | 1986 Ford Crown Victoria
I am doing a stero in a 2001 silverado with a 6.6l disel and there are 3 wires on the back of the factory stero the after market stero only have one will i need to wire the other 2 in
The best thing to do is use a factory wire adapter. The main wires you need to worry about are power, battery memory, ground and speaker wires. If you have a power antenna you will need to wire in the remote (normally blue or light blue). The only other wire should be an orange wire for the dimmer on the radio face. This one is not necessary for normal operation. Make sure you have the main 11 wires wired in. Ignition, battery, ground and the 8 speaker wires.
Apr 27, 2010 | 2001 Chevrolet Silverado
Stero installation
need wiring harness clip and install kit. It is pretty easy after that if you aren't installing amp or subs. what is your question, how to get factory radio out?
Aug 31, 2008 | Pioneer DEH-1600 CD Player
Stero wiring
Most likely the cable you are referring to is the lead in cable wire for the antenna. Below is the standard color of wires and where they are connected.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | 1994 Ford Explorer Limited
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
Oct 11, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
