No display on monitor
Hi I bought an LGA775 Motherboard with Intel Celeron D, 2GB DDR2 533Mhz, and a Geforce Graphics card and its all new. How after installing them all together and I try to run it there's no display showing in the monitor.
  • kuch26 Dec 31, 2007
    Ok For the public's information ECS PT890T-A (LGA 775) has some bugs on it. Normally, even bought new, it will not show any video display on the monitor.
    I tried everything like remove and put back tactics, clean the contacts, etc. So I tried to return it to the store (Store classified). The store said it can only be replace with same item. We did check all other motherboards and most of them are bugged with the problem I have. Luckily we got 1 good out of 5 testings.
  • sarcophagi Apr 07, 2008
    Im trying to get mine to work but no monitor works on it, i have additional videocards but i cant install them without seeing any picture. I also get no beeps whatsoever when it starts up.
THE ASROCK MOTHERBOARDS ARE VERY LIMITED ... ONLY THESE VIDEO CARDS ARE SUPPORTED:
http://www.asrock.com/mb/vga.asp?Model=P4i45GV%20R5.0
Posted on Jan 16, 2008
  • 90 Answers
Can be a problem with any of the components.
Do the power supply, cpu fan and disks start to spin after power up?
Does the PC speaker sounds a sequence of beeps? Can you identify a pattern, like 3 short beeps indicates a memory problem.
Keep posting so we can zoom in on the problem.
Posted on Dec 28, 2007
Hi guys, i need some advice on setuping my new system. here is the spec of my new system: casing- collermaster HAF 912 motherboard- MSI P67A-GD55 processor- INTEL I5 3.1 GHZ ram- 4gb x 4 total...
YES THIS GRAPHIC CARD WILL BE ACCEPTED BY MSI P67A-GD55 BOARD..
BELOW SHOWN IMAGE IS A VIEW OF NVIDIA GEFORCE GTS 450
THIS CARD ONLY SUPPORTS TWO DISPLAYS AT A TIME
May 24, 2011 | MSI N450GTS-M2D1GD5/OC GeForce GTS 450...
Computer powers up but monitor wont displays from video card, so I swithch to motherboard connectors
This may be because your graphics card is not compatible with your motherboard, If you are using a newer Intel motherboard for example with Intel HD Graphics, there may be issues with using an older GeForce card with the board.
Mar 07, 2011 | XFX GeForce 7800 GTX, (256 MB) Graphic...
I want to know that did intel d945gcr supports core 2 duo processor...............plz
This mother board will work if we have a compatible processor like Intel Core2 Duo, Intel Pentium D, Intel Pentium 4.But the processor should be greater than 2.99Ghz if the processor is less than this then it will to work.Dual core processor means there will be two processors working
The detailed specifications of the new Intel D945GCCR Motherboard are:
  • Form Factor:MicroATX
  • Processor:Intel Core 2 Duo, Intel Pentium D, Intel Pentium 4 and Celeron D processors in the LGA775 package
  • Supported System Bus:800 MHz / 533MHz
  • Chipset:Intel 945GC Express Chipset with ICH
  • Supports Hyper-Threading Technology
  • Graphics:Intel Graphics Media Accelerator 950
  • Graphics Connector:One PCI Express* x16 graphics connector
  • Memory Support:Dual-channel DDR2 533 / 400 MHz, 2 DIMM slots (2GB Max)
  • Expansion Slots:Two PCI connectors
  • One PCI Express* x1 connector
  • Audio:Intel High Definition Audio with 5.1 Surround Sound
  • USB Ports:Eight Hi-Speed USB 2.0 ports (4 back / 4 front)
  • Storage One IDE (ATA 100/66/33)
  • Four Serial ATA ports (3.0 Gb/s)
  • On-Board LAN:Intel PRO 10/100 Network connection
  • Warranty:3 year limited warranty
Hope that solve your problem!
Thanks for using Fixya!
Dec 15, 2010 | Intel D945GCCR Motherboard
Problems with 8400GS graphics card
First, you need to be sure you have installed the correct drivers for the card that corresponds to your OS.
Second, you need to go into the control panel (assuming you are running Windows of course) and tell the computer you now have a new graphics card installed and to use it instead of the default one detected when the OS was installed.
Reattach the monitor to the GeForce card and reboot. All should be OK.
Jan 06, 2010 | HP NVIDIA GeForce 8400GS - Graphics...
Nvidia geforce 9400gt 1gb card problem
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
May 13, 2009 | Computers & Internet
Geforce 7600 gs Graphics card - No Output
ooks to me you have a OS error, if you are using XP or Vista try doing a repair, then try reinstalling the VGA card Driver.
Mar 21, 2009 | PNY GeForce 7600 GS, (512 MB) AGP Graphic...
GeForce 8800 GT graphics card no display
what motherboard do you have it maybe your motherboard is only up to PCI-E 8 and the card is PCI-E 16 if it is it will not work
Jul 31, 2008 | OCZ GeForce 8800 GTX, (768 MB) Graphic...
Motherboard problem
Hiw can u say's its display problem,Have u checked the signals on k/b ?
If not check the Num lock status in keyboard. Press the Num lock key ,if the light glows and stands for sometime display is ok,but ur vga adapter is the problem.
Otherwise problem maybe with m/b or psu.
Pl check it.
Regards.
Was this soultion useful?give the apppriciation by rating it.
Apr 04, 2008 | ASUS P5K-V - Motherboard - ATX - iG33 -...
Is my Motherboard compatible?
Try to find out what the AGP voltage is on the motherboard.
Some graphics cards use 1.5 volts and some use 3.
If it's a 1.5 volt AGP slot and you plug a 3 volt graphics card in, it either wont work or you could permanantly damage both card and motherboard.
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
587 people viewed this question
Alun Cox
David Payne
David Payne
