Question about Logitech Optical Marble Mouse USB PS/2
Logitec optical mouse
How do I download my logitec optical mouse
0 characters
1 Points
Logitech Optical Mouse M-UV96 driver
make sure the battery is good ((has full charge))also you make sure the usb device for the mouse is inserted correctly into the usb port (if applicable) or if its a lead
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable)) if this fails to fix the problem you could try it in safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click to update driver
if your computer came with a motherboard disk the driver could be on it
hope this helps you
Dec 03, 2011 | Keyboards & Mice
Looking for cd for mi wireless keyboard and mous e to install into computer
You can download any Logitec software needed from the manufacturer's site. The mouse and keyboard will automatically be recognized by Windows, though.
May 17, 2011 | Logitech Wireless Access Duo Optical...
Can not install hp wireless mouse and key board.. download driver and still nothing. This is my 3rd wireless system Logitec , microsoft and now hp. I use trend Mirco service. Can secuecity stop driver s...
check do u have downloaded correct driver for ur operating system ,download it from by giving ur product no. and model no.and then try installing it
Apr 10, 2010 | HP Wireless Optical Mouse
VX Revolution Cordless Mouse for Notebooks dead as a door nail...
I see no reason that the mouse should not work. They have the Xop driver and the install software. Download both and also read henote that they are talking about in. red. I didn not download it myself. If this doesn't work you can get a common PS 2 mouse for a small amount  most anywhere including Walmart.,en?softwareid=4338&osid=1
Dec 30, 2008 | Logitech Cordless Mouse
Logitec optical wireless mouse just stop working
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 11, 2008 | Logitech 931150 Mouse
Logitec V270 bluetooth mouse freezes
I found no solution but plenty of similar complaints on the V270 on other than just Vista machines. I will suggest finding another model mouse and check it for Vista compatibility before buying.
I am using a Logitech M-RBB_DEL4 mouse made for Dell, it's bluetooth and works flawlessly on my XP machine along with the keyboard it came with. I will try the one I just ordered on my Vista machine when the BT Keyboard and Mouse arrive.
Apr 21, 2008 | Logitech V270 Cordless Optical Notebook...
Wireless keyboard & mouse not working
First download and run regscrub xp and ccleaner to clean up your system then try uninstalling and reinstalling the logitech setpoint software and try the keyboard and mouse again. Let me know if this works.
Oct 23, 2007 | Logitech Wireless Access Duo Optical...
Logitec Wireless keyboard and mouse
I presume the batteries were in correctly.
did you connect them when the computer was off, and let windows find them on bootup.
Also, make sure that you follow directions on how to get them to connect. And, make sure you run the cd that came with it.
Oct 11, 2007 | Logitech Wireless Access Duo Optical...
Logitech Optical Marble Mouse USB PS/2 Logo
Top Logitech Keyboards & Mice Experts
micky dee
Are you a Logitech Keyboard and Mice Expert? Answer questions, earn points and help others
