Question about Zenith B27A11Z 27" TV
TV wont power on
Tv popped and a smell came from it. Iv'e checked the fuses and they are good . I checked all the components and there is no visible burned componets. the only thig i found was a uncoated disc capacitor that had 1 leg disconnected and I soldered that back on.(number on circuit board is thx3415).I guess it is part of the degausser.
  • 1 more comment
  • Douglas J Platt Dec 29, 2007
    I have the origional Zenith service manual afforementioned parts listd. Can you be more spacific and tell me what the zenith # are, like (Thx3415).
    Thank You
    Doug Platt
    Would not the volume work and the tv at least turn on.
    The TV was built in 2001 and the manual does not list thx3415 anywhere except on the circuit board and in the schematic of the circuit board.Is there any ohms readings that I may get from The thx3415 or any voltage reading?
    Sergeant:
    Champion:
  • 298 Answers
Device is a thermistor (thermal resistor)
thermistor and a vatistor control the on
time of the degausser Sams Photofacts has the
schematic for the set have to match the suffixTV wont power on - 041eb6a.jpg
Some public Libraries stock photofact schematics you
may be able to go to al local library and get the part number
or the specs as to whether it is ptc or ntc etc to get a match
or online here
Posted on Dec 28, 2007
  • 2 more comments
  • Eugene Merritt Dec 28, 2007
  • Eugene Merritt Dec 29, 2007
    Schematic should describe thx3415 and identify it
    I said it probably a thermistor based on your
    description thermistor are PTC positive termp comp
    ensation or negative comp NTC what does the
    schematic saly that thx3415 is? does it give a
    NTE or Zenith parts # if it is Zentith part # you
    can cross reference it with NTE part
    Check if the Varsitor is open, if it is in series with
    the power supply it will prevent the power supply
    from working,Also the input ac transformer, and
    low voltage transformer promary winding if exist
    What year is that TV
    you need a Sams schematic you need the
    part number for the varistor it is usually in
    parallel with the thermistor I think you
    just have a basic wiring diagram or something
    voltage reading are on a schematic you are not
    getting anywhere without the schematic the
    numbers are right on the jpg did you check
    with a library or with Sams you need the
    part# of thermistor and varistor as I told you
    Send me a scan of the power supply section
    of the schematic
    Sergeant:
    Champion:
  • 209 Answers
Maybe its the tube or the screen burnt out ?
After a power outage my Panasonic smart tv came on for 2 seconds but after that it turned off and it wont come on after 24hrs
The power outage probably popped an inside fuse or damaged some electronic components. If you are capable, unplug the tv and place it face down on a soft towel. Unscrew all the screws on the rear that hold the two halves together. Lift the back panel slowly making sure all is free. Look for the fuses and check if they are blown. If they are, replace them with the same rated fuses. This is the cheapest fix. If the fuses pop again after this, then something beyond the fuse was damaged. You will need a repair shop to troubleshoot it. Once fixed, plug the tv into a surge protector for future use. Hope this helps.
Apr 09, 2016 | Panasonic Televison & Video
Plasma made a loud pop then shut off and will not turn back on. There was also a burning smell. Any suggestions on a fix and price is appreciated.
Having similar problem and it sounds like an obvious short circuit if you heard it and can smell it, and it probably took out power supply fuse, so the first thing to do is pull off back of TV and look for obvious toasted components by eye or smell. Capacitors sometimes will pop when they go, and you can see the tops will be bulging out, or black marks, so look and smell all large capacitors first on power supply main board, then check to see if fuse blew. Sometimes the obvious is easy to fix.
Good luck,
Sep 30, 2012 | Dell W4200 42 in. HD-Ready Plasma...
Burnt smell
Check the main power supply regulator section for faulty component/s. The sound you heard might be of a bursted electrolytic capacitor at the power regulation stage circuit, due to some spikes in the input AC voltage. Open the TV and check this section. Be sure to unplug the TV from AC mains wall socket, before open it.
Jul 23, 2012 | Zenith B36A24Z 36" TV
Hello. My tv will not turn on. I metered the power circuit as far as I could, and it looks ok. The fuse on the control board is good. The power switch meters good. When the tv failed I heard a small...
It sounds that the power supply regulator section or main board has the fault. Check it with the help of schematics. If you are not handy, seek any technician's support.
Jun 18, 2012 | Emerson EWF2006 TV
I have a LG 37lc2d and it suddenly turn off and wont come back on, the stand by lights doesnt turn on either. i was wondering if its just the power supply? or how can i troubleshoot this my self to see...
There is a fuse on the power supply close to where the A/C is connected to the board. If the fuse is blown, look at the board and see if there are any burned components and or swollen capacitors. If there are bad components, I would suggest getting a new board.
If the board looks OK, disconnect the connectors from the board but leave in the A/C connector (this way you can isolate the power supply board), replace the fuse, and power up the TV.
If the fuse pops after the power is applied to the unit, then the power supply is bad.
If the fuse is still good, then power off the TV, connect on the main board’s connections, and power up the TV.
If the fuse is still good, then power off the TV, connect the inverters, and power up the TV.
If the fuse blows now, then the inverters and or the panel are bad.
A working power supply will create 5vdc for the main board’s stand by source voltage. This can be found on the power supply at the main board’s connector and it is labeled in black text.
I hope this information helps you.
Good Luck.
May 28, 2010 | LG 37LC2D Television
MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Jan 05, 2009 | LG RU-27FB30C TV
Tv won't turn on
my funai 3216 was working ok it went off today and wont come back on iv changed the fuse in the plug with no luck iv taken the back off the tv what next please help
Jun 22, 2008 | Televison & Video
TV won't power up. I herd a popping noise and now the TV won't turn on.
A popping sound can be a good thing because it will be easy to identify a blown up or degraded component,if you are familiar with tv service you might spot the bad part fast just by looking at it and then change it,sometimes you actually have to check a component with a meter to tell is gone bad,check the main fuse ,it should be close to were the power cord comes in,if is black you will have bad components ahead and you will need the assistance of a servicer,if you are not too familiar be safe and call for help.Let Us know how it goes.
Oct 10, 2006 | Hitachi 50UX57B 50" Rear Projection...
Pop and burning smell now no picture
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Jan 03, 2006 | RCA Scenium HD65W20 65" Rear Projection...
Zenith B27A11Z 27" TV Logo
215 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
