Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vista tells me that Seagate Freeagent Go has no drive connected. What to do?
  • Anonymous May 11, 2010
    are you logged on as administrator,are you pluged in a 2.0 high speed port?,in cntroll panel,device manager/hardware,usb must have the word enhanced somewhere in the title,or is not a 2.0 port,is it new?,what kind of computer is it,please be more specfic,these kind of problems need all spec.for best chance of getting good solution,post comment with details,and ill try to help,aloha from maui todd0708
Anonymous
Level 2:
  • Expert 105 Answers
  • Posted on Oct 18, 2009
Anonymous
Expert
Level 2:
Answers
105
Questions
Helped
46532
Points
247
Http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=hard-drive-basics-dn&vgnextoid=2df42bb581b51210VgnVCM1000001a48090aRCRD
Ok above is a link to inform you of how to reformat and troubleshoot you're HardDrive I use Vista premium sp2 So you ma want get sp2 installed and it generally resolves issues promptly There is also software the may help your current situation
Seagate backup plus is beeping and will not pull up on computer??
Troubleshooter: Seagate Manager does not see my Seagate FreeAgent drive Troubleshooting in case the Seagate Manager cannot detect the FreeAgent drive.
Sometimes, Seagate Manager (the software bundled with newer FreeAgent drives) does not see the drive.
This article focuses on drives that can be seen in Windows, but are not seen in the software.
If you are using Windows 8, please note that Seagate Manager is not supported in Windows 8, so you will need to use a different backup solution.
If the drive is not detected in Windows 7/Vista/XP, then use the external drive troubleshooters to try to resolve the non-detection issue.
After connecting the FreeAgent drive, please give it up to 1 minute to display in the middle of the main screen in Seagate Manager.
If the drive does not display, open My Computer (Computer for Vista) and confirm the drive is listed there. The drive should be listed as "FreeAgent Drive". If you have formatted or renamed the drive, then it will show up with the name you provided.
If the drive does not display in My Computer (Computer for Vista), use the External Drive Troubleshooter to help resolve that issue before continuing.
If the drive is detected in Windows, check if the Seagate service is running.
  1. Right-click on the My Computer (Computer for Vista) icon.
  2. Choose Manage.
  3. In the Computer Management window, click Services and Applications.
  4. Open the Services area.
  5. Scroll down the Seagate Service (they are listed alphabetically).
  6. The Seagate service should display Started in the Status column.
    If it does not, right-click on the service and choose START.
  7. If the service reports as Disabled, enable it to start automatically.
    To do this, right-click on the service. A Status Type drop-down menu will appear. Click on the General tab. Select Automatic and click OK.
  8. Reboot the computer.
  9. If the service fails to start after you reboot with these settings, then check the logs of your Antivirus or Antispyware software to confirm they are not restricting the startup of this service, as some aggressive protection programs can prevent services from starting until you approve them. So, you may need to approve this program specifically in the Antivirus/Antispyware software. Please contact your anti-virus software support for help.
  10. If the service will not start or is working already, uninstall the software (for steps on uninstalling the software, see this article).
  11. Once the software is uninstalled, reboot the computer.
  12. Then reinstall the software by opening the InstallSeagateManager.EXE file on the FreeAgent drive. If you have removed the software from the drive, it can be downloaded from the download center.
  13. If the drive is still not seen by the computer, connect the drive to other USB ports on the computer.
    Some eSATA cards block the drive's identity and prevent it from working. Updates have been made to Seagate Manager and to some vendors' eSATA drivers to help this issue. See our eSATA tips article for details.
  14. If the drive still does not display after these steps, please contact Technical Support.
Check Required Windows Component Installations
1. Check to make sure you have the MSXML Parser 6.0 installed:
  • Open Control Panel
  • Open Add/Remove Programs / Programs & Features (Vista)
  • Check box for "Show All Updates"
  • Look for "MSXML Parser 6.0"
If this is not found, visit Microsoft's website to install this component: http://www.microsoft.com/downloads/details.aspx?FamilyId=993c0bcf-3bcf-4009-be21-27e85e1857b1&displaylang=en
2. Make sure Microsoft .Net Framework 3.5 installation
  • Look for "Microsoft .NET Framework 3.5".
If this is not found, visit Microsoft's website to install this component. 3. Try the steps listed here.
4. Remove the Seagate folder from C:\Documents and Settings\All Users\Application Data (XP) or C:\Program Data folders (Vista) and reboot.
5. Download and install the newest Windows Installer.
6. Download newest Seagate Manager from our Website and re-install a clean copy. Note: Do not do the update when the message pops up saying one is available.
1helpful
Hi,how can i format my seagate freeagent goflex 750 to fat32 ?
Welcome to Fixya. Once you connect the harddrive on the computer go to my computer or computer then right click on the seagate drive then select format. On the window that will pop out on the screen select Fat32 then format the drive. Please use windows xp or 7 because vista don't have fat32 but exfat.
Thanks
1helpful
We've a seagate FreeAgent Desk 1500GB drive that was working fine on XP and Vista, until today when it it is a read-only disk on vista computers. Works fine on XP. Any suggestions on how to get the write...
You must change the permissions for this drive.
Right click on the drive and select properties, then look at the security tab.
Use the edit button.
Then select your ID and check off all the boxes under permissions for users.
I have just purchased a Seagate 500GB Desktop hard drive
There is software preloaded on the disk. If you have AutoPlay turned off in your system, it won't start automatically when you connect the drive. Just go to MyComputer and open the drive and you will find a setup file there to install the backup software (I think it's called Launch.exe).
Freeagent with server 2003 not working
Seems that Seagate did not release a version of software which could be used on a Windows Server 2003 platform. I checked their web site at the following link & didn't find any software supported on Windows Server 2003:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Sorry, but I can't help you with this one. Try contacting Seagat for this & see if they have a solution to your problem.
Windows vista on Vaio laptop does not detect new Seagate FreeAgent Go 250 USB 2.0 GB drive.
try formatting your laptop again with vista O.S. but dont install anti virus after installing it because there might be some conflict with the anti virus you installed with the O.S.
6helpful
2answers
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Seagate Hard Drive issue
i want drive freeagent pro 500 gb firewere400,usb2.0, eSATA
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
