Question about Bosch Axxis WTL 5410 Electric Dryer
Bosch WTL5400 Condensation Dryer
Lint filter is constantly going off. Checked drain line and no blockage. Cleaned drum sensors and filter. Checked heat exchanger. Turns off after 15 mins or so because of lint filter beeping. Help!
  • 3 more comments
  • Anonymous May 02, 2008
    Same with wtl 6401 /Erik
  • network2525 Jun 16, 2008
    Lint filter alarm is always going off. Cleaned lint filter, air intake and the heat exchanger......still it goes off. Appears worse when there is high humidity.
  • Anonymous Aug 18, 2008
    Same here in Finland....sensor broken??
  • Anonymous Oct 19, 2008
    Same problem
  • chrisp870 May 12, 2009
    Same problem, I've cleaned the lint filter, the condenser, taken the back off the dryer and cleaned those areas, but still the beep..beep...beep lint filter! Help?
    Problem Solver:
  • 7 Answers
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Posted on Oct 25, 2008
  • 36 Answers
Check your vent for blockage mashed vent turn drier on go out side and check flow
Posted on Dec 29, 2007
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
Bosch WTL5400 Drier runs fine for 5/10 minutes, then it stops and the "start" light flashes. Pressing this then restarts the process, but a few minutes later it cuts out again. I have checked...
I have the same problem, the dial to select the dry program is making a bad contact causing it to stop. Try using a different program.
I tried to clean the dial but it didn't help.
Dec 06, 2010 | Bosch Axxis WTL 5400 Dryer
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal F3 which says to check condensation outlet and I have cleaned all the parts and cleaned hose but it will still beep after a few...
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Sep 22, 2010 | Bosch WTE86300 Electric Dryer
My dryer has a build up of water and give an F03 error. What can do to fix it?
Aug 08, 2010 | Bosch WTE86300 Electric Dryer
I recently had an ventless Bosch dryer installed (WTE8600US) and I keep receiving this message F:03 which the manual says "check hose for condensation outlet". any advice?
For the F:03 problem on the Bosch Axxis (WTE86300US) do all the things mentioned in Solution #1 above. Sometimes the lint in the condensation filter channels (those that run from front to back)can be quite stuck. Use a pipe cleaner to get in there or a garden hose with a spray nozzle. However there is one more crucial step not mentioned in the manual or in Solution #1. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver and gently pop it open. Under the panel is a small chamber where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place. This should fix your problem.
Dec 13, 2009 | Bosch Dryers
Dryer not working, indicates "lint filter" When I try to use the dryer (Bosch Nexxt), i first turn the dryer to the setting desired (regular or perm press, and time) it immediately has the "lint filter"...
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Sep 01, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Hello, getting an error of F:03 on my WTE86300US Bosch Condensation Dryer. Do you know what the issue is?
Aug 06, 2008 | Dryers
Lint filter wanring signal
I posted in late December on the lint alarm and what I discovered was a bit alarming. (no pun intended) Lint had been accumulating on and around the heating coils used to dry our clothes. Some of the lint was burnt and the remainder, amounting to a small handful, was caught up in other area's around the lint sensor. After carefully cleaning the heating coils (with a tooth brush) and removing the rest of the lint and successfully putting everything back together, we have not had a lint alarm issue since. (Touch wood). No need to replace the lint sensor or any other parts. It was not that hard to take apart the back and remove the heating coils to clean, but it requires the unit to be unplugged, careful attention to what came off and where it goes back on. After what I found, I will be cleaning the heater coils out once a year. Which then raises the question. Should a person have to do this? The obvious answer is no! But from time to time we buy things that are not what we would expect and do what we need to do to make it work. From what I can tell, lint is getting past the lint filter and ending up where it shouldn't be. Hope this helps any of you that are having the same issue.
Mar 04, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
1,445 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
