Question about LG LRBC22544 Bottom Freezer Refrigerator
Back reservoir Hello my husband and I just bought this used refrigerator, as soon as we hooked the waterline to it and pressed it for water to dispense, none did. I opened the door and water just came out. Turns out a white "S" shape reservoir that stands behind the 3rd compartement has a tear in it and the water comes out from it. If froze on the bottom of the refrigerator, It's been 2 weeks and these people have not fixed it. I want to know where I can get this part new since this model has been discontinued. Thank you
  • dalehenry Nov 30, 2008
    LG25850 leaking water reservoir in French door. How do you hook up the tubing after the tank is removed and how is it coiled? How long of a piece of 1/4 inch tubing is required?
    President:
  • 878 Answers
Kiwy, your part number for this reservour is 4838jj1003a. Since they had a lot of problems with this tank they replaced it with coiled plastic tubing. You can find the replacement part at repairclinic.com, it will show you a picture of it. Or you can go down to your local hardware store, buy some 1/4 inch plastic tubing for water and 2 quarter inch John guest fittings to hook it up. That's all it is now, is coiled plastic tubing to chill the water. Catriver.
Posted on Dec 28, 2007
Where can I find a waterline for my GE glm23qeta gRefrigerator
Take a piece of your current water line to the local appliance store. They will probably have what you need.
Mar 29, 2016 | GE Refrigerators
Ken more elite trio model number 596-73502201
Make sure water is turned all the way on. If still not getting water, you might have to check the screen inside the water valve to make sure it's not plugged. Also make sure your electrical connection on water valve is on securely.
Nov 10, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
Just purchased a fridgidare Gallery Series counter depth side by side fridge. was delivered today - water line hooked up. as soon as we turned on the water and pressed the dispenser water was pouring out...
Check water line just below the freezer door. This is where there is an water-line hook up that may not be connected.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - We repair refrigerators and all other appliances in the Houston, Katy, Spring and Woodlands, TX areas!
Aug 29, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
The ice maker works and the water dispenser is not working. We noticed last week that the water wasn't coming out as cold and we changed the filter yesterday but it isn't working??
Check temp setting between 3 and 5 degree. And also check due to over frosting, waterline to dispenser clogged. And also check water hose is no dusty. Thanks.
Feb 07, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Need to know how to hook waterlines up
Good Afternoon, JohnHerren27:
Here are the instructions to install your water line:
http://whirlpool.custhelp.com/app/answers/detail/a_id/975
and your parts can be found here:
http://www.repairclinic.com/Whirlpool-Refrigerator-Hose-Tube-Or-Fittings-Parts
Literally fresh water in minutes.
Chr
Aug 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hello i have a wirlpool fredg it stop giving water but it still make ice normally and all filter are good what would be the problim .please help
the inlet valve on the back where the waterline hooks in has two solenoids. one for ice and one for water. I would start there.
Jun 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
BITTER SMELL AND BAD TASTE IN ICE IN FREEZER
try putting an inline filter in your water supply line before you hook it to the waterline
Jul 12, 2009 | Refrigerators
Tring to hook up waterlines to dual valve
Probably to the filter is where the other one goes if you have a filter.
Jun 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice/Water Dispenser in Freezer door not working when you press the lever. Also the light dims when lever is pressed. Icemaker working fine.
Sounds like a frozen waterline. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 28, 2007 | GE GSS20IEP Side by Side Refrigerator
LG LRBC22544 Bottom Freezer Refrigerator Logo
261 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
