Question about GE Washing Machines
GE Warsher Filter-Flo problem
My GE top load warsher is having problems with the Filter-Flo. The stream does reach into the removable top filter basket. It is so slow that it reaches just outside the top filter basket and streams directly into the tub. By this it is not able to filter lint or any thing else it is just getting throwed back into the load. Any advice on how to get it to flowing properly. Thank You - Malissa.
  • 1073 Answers
SOURCE: LINT FILTER
no lint filter in machine
Posted on May 27, 2008
SOURCE: remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Posted on Jun 07, 2009
  • 634 Answers
SOURCE: Lint on dark clothes
no product i know of , try running machine without cloths with hot water and a lot of extra soap the unrestricted water movement and extra soap lubricates and helps to flush machine out, let machine dishcharge into bucket and if poor flow or lots of debris run again and see if this clears up you issue
Posted on Jul 07, 2009
  • 512 Answers
SOURCE: lint filter on GE wbsr3140dw
Open the door and lint trap is right in front, just pull up and it comes out. Clean and replace.
Posted on Sep 23, 2009
cmm19987
  • 82 Answers
SOURCE: How do you open the top of ge washer model WJRE5500G2WW
You may need to put a level on top of the washer and then there are little feet like under the washer you will need to turn those either way untill all 4 are right, meaning once the level says it is level then you are ok and avoid overloading.
Posted on Nov 10, 2009
How to replace front washer motor
the warsher pump in located in the washer fluid jug remove jug pop it out and put new on in
Oct 25, 2013 | 2001 Chrysler Town & Country
Kenmore warsher, Model num 110.14202300, not drain or spin
The clothes too wet after spin cycle tells me that the water ump is functioning. If it wasn't, there would still be lots of water in the machine when the cycle ended. These Kenmores have the water pump mounted on one side of the electric drive motor and the transmission, drive shaft, and agitator on the other side. The transmission is fastened to the motor by a "coupler", a three piece assy that often breaks. This common failure allows the machine to complete a cycle, however, because of the broken coupler, there is no drive to the tub and no spin or agitate. The clothes seem wet because the spin motion is supposed to provide the force to extract the excess moisture. Leave the lid open and verify that there is no agitate or spin.(During spin cycle use a pen to press down on the safety interlock, a small opening on the the of the machine, toollow the unit to spin with the lid open). If you verify this, flip the machine over and locate the coulper on one side of the motor. One side will be cracked along the shaft. Sears parts stores carry the coupler in stock. ($18.50) Hope this helps.
Jan 18, 2010 | Kenmore 22422 Top Load Washer
Older kenmore warsher, Model num 110.14202300. not drain or spin
If it won't drain or spin check the lid switch. If it sounds like the motor is running when in spin check the coupler between the motor & and the transmission will have to pull the motor to get to it.two plastic parts with a rubber piece between them.
Jan 02, 2018 | Kenmore Washing Machines
F-02 error on wash and spin cycles
if you take the front cover off. there is a big knob behind it. this is a strainer (filter) unscrew it.
caution there could be water!! use a towel or something under the warsher. its probally pluged if not it is the pump
Mar 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Machine stopped in middle of wash cycle.
Timer needs replaced try gigling your timer knob and see if you get any reaction dont be afraid gigle it up and down hard sounds like point in timer are burnt
Sep 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwasher model DD603 Fisher&paykel
try to check the plug and the wire
Jun 27, 2008 | Dishwashers
Dryer will not dry !!?
Is it a new dryer? Is it Used? Model # so that it can be easier diagnosed.
Mar 20, 2008 | Dryers
Washing Machines Logo
79 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
