The f1 symbol along with a wrench on it stated flashing and i dont know how to switch it off
The flood switch has been activated. This can happen if a hose busts or something, but more often than not it's because you put something too tall in, and the lid that seals the drawer could not close all the way.
If you don't want to pay a technician you can probably solve the problem by drying it out yourself.
Switch the unit OFF at the mains.
Open the lower drawer. There is a tab on each side that you click and then can slide the drawer off its runners.
Use a towel to mop up as much water as possible, and then get a hair dryer onto it to dry any remaining moisture.
Then slide the drawer back in and let the tabs click back into place.
If the F1 still shows there may still be some water, OR you could have a busted hose or something.
F1=flood water leak
On most laptops there is usually a symbol of an antenna or something along those lines to illustrate wifi connectivity on the funtion keys (F1, F2, etc..) Press the function key 'Fn' and the key with the wifi symbol simultaneously.
