Question about Sony SA-FT1H TV Speakers
Sub-woofer Malfunction Sub-woofer will not always go into standby mode when input is terminated.
    Novelist:
  • 148 Answers
Sub can be detecting signal from your amp. maybe your amp has some small output when in standby mode. some amps throughput signal from satellite boxes when they are supposed to be off.
try shutting off that signal source as well.
good luck
mark
Posted on Dec 28, 2007
How to connect a jvc Rx 516v amplifier to a four terminal sub woffer
Connect both speaker outputs from you amplifier to the left and right inputs on your sub woofer. Connect your normal speakers to these connections on the sub woofer.
Mar 04, 2015 | JVC Audio Players & Recorders
My wireless subwoofer keep cutting off and coming back on when the music or movie is playing
Some/most Sub Woofers have a Switch that turns them Off/On/ or Auto. On Auto, the Sub only turns on when there is a signal present. ( sound coming into the Sub ) When there is no signal, the sub goes into standby mode. Wireless subs may be made to be in standby mode as the default.
Dec 21, 2014 | Audio Players & Recorders
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
What is a sub woofer pre-out ?
Sub-Woofer pre out is for connecting that terminal to the input terminal of any sub-woofer. The sub woofer which it should be connected must be an active type [that is, there must be independent amplifier section built it with that sub-woofer; not mearly a crossover network].
Oct 22, 2012 | Denon RC-920
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
Mar 12, 2011 | Audio Players & Recorders
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
I lost my remote control and I want to turn on my sub woofer manually through my receiver. How do I turn on my sub woofer.
Perhaps I misunderstand the question.
Depends on the Sub. Most powered subs will go into standby mode in the prolonged absence of a signal. Then they wake up when you play something.
Or are you saying you need to Enable the Sub, as in setup? Remote probably required for anything like that.
Dec 02, 2009 | Aiwa AV-D58 Receiver
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 | JVC RX-778V
Sony SA-FT1H TV Speakers Logo
356 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
