Question about Sony PlayStation 2 (PS2) Console
Ps2 Slim power wont stay on
Hello I have a ps2 Slim and my power wont stay on. I have to put excessive force on the plug that connects to the ps2 in order for it to stay on but usually it will run for a second and cut off. Any help should I just get a new power cable
  • aya0708 Jun 09, 2008
    i have the same problem. The power only seems to work when I push on the plug connecting into the slim ps2 and turning it or keeping it in the same position. If anything moves or shakes it loose the red light turns off and no power goes through, or resets itself to green from red.
  • Anonymous Apr 07, 2009
    Yea its fricken annoying i have the same problem
    i got it fixed once
    then 6 months later the same problem
  • 30 Answers
Hello klawyer, I Think It would be a good Idea To Try and get a new power cable, but Also you should check for signs eg. If its oldish, Has the plug pard got a bit rusty, is it the wrong cable?. If none of this work, try going to your local Video Game Shop, I Recomend Game and tell them your problem.
Posted on Dec 29, 2007
My PS2 wont turn on
is either the power cord plugged in all the way in back of the system, or is the switch on the back turned to on. This may work for ps2 non slim.
Jun 10, 2013 | Sony PlayStation 2 (PS2) Console
My slim playstation 2 is not working need answer quick
Haha i understand your distress :) if your slim ps2 is not turning on, first check and make sure that all your wires and stuff are all plugged in to EVERYTHING. also, make sure your outlet works too. corroded electrical outlets wont work. Also, make sure your PS2 cooler is not blocked in any sort of way. if you need any more issues, just ask :) ~~RJ~~
Sep 19, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 slim 90001 no power
maybe u play it to much or some thing is wrong with the plug or u can open the ps2 check wear the plug goes in
Jul 23, 2009 | Sony PlayStation 2 (PS2) Console
My playstation2 slim power light blinks and wont turn on what can i do
this solution usually works after your slim PS2 shocked you when you touched the reset button, but you can try it-- it's from the manual:
1. unplug the PS2
2. wait for 1 minute
3. plug in PS2
hope this helps :D
Jul 05, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 slim console wont turn on!
i checked the manual (troubleshooting) 1. turn off PS2 2. unplug it then, plug it back in and turn it on(andprayitstillworks).
Jan 10, 2009 | Sony PlayStation 2 (PS2) Console
My sister misplaced the laptop power cord for a ps2 cord now the ps2 wont spin or read discs !
Go to Ebay and put "PS2 Slim power adapter" in the search box on Ebay. Look for a good deal and happy bidding.
Jan 30, 2008 | Sony PlayStation 2 Slimline Console
Disc wont work
Hi AdalVI,
Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Slimline PS2 Power Problem
What do you have to hold down, the cord from the adaptor to the machine or the cord from the plug to the adaptor? Did you get a shock when you first tried holding the cords down? The cords are pretty thick and the insulation should not peel off at all unlees you are also twisting the cord. Also if you lay the console flat instead of using the stand the problem may clear up, because you won't be twisting the cord.
Sep 20, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
153 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
