had strange odor after running for a 2 hour cycle turned off unit just went to turn on today and it wont turn back on? Fuse is not located where the manual says it should be between the on/off switch and the cord plugin port?
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi...
(More)
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi is that?
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest...
(More)
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest fresh air
I have 2 ecoquest fresh purifiers 1 will not power on would that be a fuse issue and the 2nd the...
(More)
I have 2 ecoquest fresh purifiers 1 will not power on would that be a fuse issue and the 2nd the sanitize mode won't work would that be a starter balas(ms)???can you help???
