Suddenly my WD external 500GB My Book dropped off my control panel and doesn't respond. I am hoping that it has not crashed. It is not more than 2 years old. It has some pretty important work files on it as well as HD backup. The USB works fine, so it is not that. What can I do?
If that doesn't help, I would assume the worst and begin working on data recovery to be safe.
Try a free download of Seagate File Recovery.
You can preview your disc and file content in a simple hexadecimal viewer which tells you if a successful recovery is possible. You'll know in advance exactly which files can be recovered before you make a purchase.
If your files are recoverable, simply purchase the software for Windows or Mac and restore your files. It's that easy.
My WorldBook is on my home network. Sometimes I can see it on the network tree, othertimes I cannot....
(More)
My WorldBook is on my home network. Sometimes I can see it on the network tree, othertimes I cannot. I create a 'share folder' for an external drive and it used to always be available, but recently that folder will become non-existant and I have to recreate it.
I have a WD MyBook backup drive. It has not successfully backed up since Sept-Oct. When it tries to...
(More)
I have a WD MyBook backup drive. It has not successfully backed up since Sept-Oct. When it tries to back up now, I get an error msg that makes no sense to me. Help!
very slow to open files, several do not open. does not allow deletion of files, all files affected...
(More)
very slow to open files, several do not open. does not allow deletion of files, all files affected are photo files. virus scanned regular - no issues
I have a WD 500GB My Book World Edition and only need to use it for back up...problem: I've hooked...
(More)
I have a WD 500GB My Book World Edition and only need to use it for back up...problem: I've hooked up the ethernet, power cable, and installed the software but when I try to back up my C drive: only the C Drive is listed; My Book is not listed. Any ideas? Must I also install MIONET if I don't need to use it? TY
