a) check the 3A diode on the secondary of the transformer might be
shorted.
b) check if there is 5V on its output
c) if a is good no shorted diode on the secondary your main regulator is busted. it has a part number printed
d) might as well check/replace the resistor with a value of 150K
color code = brown- green -yellow, yours might be diferent
e) to test for voltages the negative probe (black) in the chassis
Comments:
Oct 19, 2009
- post the part number of the IC you are looking,
the one that have 4 pins is the optocoupler
you need to replace the one that have 8 pins on it
only if there is no voltage or short on the secondary side
Oct 19, 2009
- the optocoupler is the one controlling the main regulator ( maybe 8 pins)
Oct 19, 2009
- these optocoupler needs only 1.5V to turn on the main regulator
sometimes it comes from the 12 v output supply , it triggers the main regulator
without the standby 5V your main regulator will not work.
Oct 19, 2009
- if still in doubt, post the part number of the IC you see , and i will identify the IC for you.
with the complete markings or label .
Oct 20, 2009
- the one you need to replace is the IC that is directly connected to the chopper primary
transformer.it is controlled by an oscillator to produce output on the secondary.
it has also a start-up resistor maybe about 75K to 220K
