Question about OKI C5200n Laser Printer
380 Paper Jam Error just before blue toner is laid down
I cleared a couple of paper jams from the front pickup unit, removing a small triangular piece of paper that had torn off in the machine. After that I cleaned the inside of the machine, picking up a lot of toner dust with a vacuum cleaner and lightly wiping inside of unit walls with all image drums out. Ever since the cleaning the paper will pickup fine and move through the unit under the image drums, but stops just before entering the fuser unit.....and then I get the "380: Paper Jam" error message. Also, the cyan toner has not yet been laid down on the copy before it stops.
The paper is not actually "jammed" as all I have to do is remove the image drums and lift the paper off of the "shiny sheet".....it just stopped before proceeding on past the cyan toner and through the fuser.
1. Is what I have described a typical symptom of something I can fix? If so how?
2. Where can I get a copy of the repair manual for an OKI 5200n. It sure would be easier to evaluate the problem, understand how the machine works, and even know the correct names of the parts...like the "shiny sheet under the image drums", if I had an official manual? The little Handy Reference Guide isn't of much value.
Thanks to all of you gurus out there who are willing to help us novices.
Wendy
  • 2 more comments
  • wendydot Jan 03, 2008
    Soulvisitor -
    Thanks for the reminder of the User Manual online....that was very helpful.
    After doing some more troubleshooting I see that the cyan toner IS being laid down. The sheet does not move into the fuser unit - all action stops at that point, but it does appear that all 4 toner colors are being laid down properly.
    In addition to the Paper Jam error message, my Okidata is telling me that my Y toner is empty (although I just bypass the error message and it still prints out yellow), that the K drum life is about to reach its limit, and that I need to order M toner.
    Since this unit is so intuitive, is it safe to assume, in a perfect world, that if any of image units, or the transfer belt or the fuser unit were damaged that the unit would display such an error message?
    I have looked into replacing the image units, the fuser unit and the transfer belt, as well as installing new toner cartridges..........but it will cost a small fortune to start replacing $50 to $200 items just taking a shot in the dark that fixes the problem.
    Right now I'm seriously considering abandoning my relationship with Okidata and buying a new HP inkjet printer. I just want a reasonable quality print with the least investment of time and money.
    My front office window leaks cold air........I'm considering throwing my c5200n through the window and replacing both the window and the printer.
    wendydot
  • dhcollins1 Feb 21, 2008
    After a toner mishap replacing the K toner, after attempted cleanup I get error message 380 paper jam. the paper travels as far as the Y cartridge and stops. It would seem something still needs to be cleaned but I don't know what.
  • Eric Fenstermaker Sep 04, 2008
    Same problem. I also checked the front for jams and found one. Machine worked for 6 prints then same error 381 appeared again and paper stopped just before fuser unit. I removed paper and now 381 message will not clear.
    Same exact problem. I did manage to clear it once by opening front cover bbut after 4 prints problem happened again and now I can't clear it. Help !
  • OKI Master
  • 1,113 Answers
It sounds like the problem is with cyan drum, drum cover broken?, The fix I'd follow without looking is replace cyan drum (or possible remove drum cover completely if broken) but it could also less likely be the Transport Unit aka "shinny" it just clicks out too for inspection
Keep fingers off drum's and trans unit surface.
Service manual is japanesse english limited stuff, trust me they are not much help, try the user manual it at least has the names of stuff. User manual is on disc that comes with printer or via download from oki's web support page.
Feel free to post back
S.
Posted on Jan 02, 2008
  • Soulvisitor
    Soulvisitor Jan 03, 2008
    Wendy.
    "The sheet does not move into the fuser unit - all action stops at that point, but it does appear that all 4 toner colors are being laid down properly.". then replace fuser or ensure it is seated fully......another consumable.... also check that this 380 error is happening on a sinlge print and is not the result of printer having trouble with next page pick up.
    All these consumables are needed to be replaced at one time or another, bypassing their replacement just makes fault finding more difficult, So put in a k drum, y toner order the M toner, check fuser life, inspect it for damage (gears/wrinkled orange rollers) and replace that too if older than a year or life low or damaged.
    "In addition to the Paper Jam error message, my Okidata is telling me that my Y toner is empty (although I just bypass the error message and it still prints out yellow), that the K drum life is about to reach its limit, and that I need to order M toner"
    You are not saving any toner use by bypassing y toner empty you are depleteing the reserve that is held in drum unit, soon you will lose yellow colour in prints and start wearing drum surface early, and when you do finally put in y toner it will fill back up the reserve and may even show empty again as the result., when k (black) drum reach's 0% printing will stop. M is just warning low, will soon go also to replace m toner
    ".Since this unit is so intuitive, is it safe to assume, in a perfect world, that if any of image units, or the transfer belt or the fuser unit were damaged that the unit would display such an error message?"
    No it will not detect any damage to units, It only counts by prints done, it does not take into considereration worn by age, it will notice some critical faullts. It is warning you now that these items are at end life so first step is to replace as it has told you already.
    Colour printing costs money about 20-30 cent per page any printer is the same. You will need to replace the parts when their life is ended.
    If you dont change the tires in your car or dont put water or fuel or oil in it it will break down or perform poorly, no difference with the printer.
    Yes parts are expensive, but this machine is designed to be technician free, user replaces the parts cause I am more expensive than any parts.
    If you want cheap printing brint with a b/w laser, OKi printers are not that expensive compared to the other full colour machines in the market.
    Hp inkjet will cost more to run but great if you are low volome, hp uses two 60 buck carts that last maybe 100 prints.
    Windows are expensive throw down stair well!
    "I just want a reasonable quality print with the least investment of time and money." use a print shop or b/w laser, inkjets are the most expensive print option to run, best most economical colour printers are Sharp MX copiers, Kyocera lasers and OKI's, HP lasers
  • Soulvisitor
FS-3900DN rear unit paper jam
Hello, Power down the unit.Unplug power from wall. Power back up, if the error still happens, there is a small piece of paper somewhere, take toner out and look, or pull down back cover and look in there.
May 22, 2014 | Kyocera FS Office Equipment & Supplies
Hi, My printer had a paper Jam and I am pretty sure some paper got stuck however i cant find any when lifting the top up.It now wont work and the alarm light is flashing ThanksJemma
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. Step2 Turn off the printer. Step3 Remove any paper trays. Inspect them for wrinkled or damaged paper. Step4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. Step5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. Step6 266_a1.jpg If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. Step7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though. Step8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Step9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
If you still face the problem let me know..
Goodluck..
Jun 03, 2008 | Canon Office Equipment & Supplies
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
DRUM ERROR - HAD PAPER JAM, CLEARED THAT AND NOW IT WILL NOT PRINT - KEEP GETTING DRUM & ERROR
Sorry to hear you are having problems. Printers can be very frustrating at times. Below is a description of how to complete clear paper jams paper can get jammed it there pretty tightly and in very small places. Ensure you've followed all the steps to clear your paper jam and you should see your printer start working again. Refer to your user guide (or download via the link provided at the bottom) for illustrations.
  1. Open the front of the printer.
  2. Slowly take out the drum unit and toner cartridge assembly. Some of the jammed paper will be pulled out with the drum unit and toner cartridge assembly.
  3. Set the drum unit and toner cartridge assembly on a piece of disposable paper or cloth in case you accidentally spill or scatter toner.
  4. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes inside the printer.
  5. Close the front cover.
    Note: Do not put the drum unit and toner cartridge assembly back in at this point.
  6. Pull the paper tray completely out of the printer.
  7. Pull the jammed paper down and out of the printer.
  8. Open the back cover (back output tray).
  9. Still looking at the back of the printer, pull the tab toward you to open the fuser cover.
  10. Pull the jammed paper out of the fuser unit.
    HOT SURFACE
    After you have just used the printer, some internal parts of the printer will be extremely hot. Wait for the printer to cool down before you touch the internal parts of the printer.
  11. Close the back cover (back output tray).
  12. On the drum unit you set aside, push down the green lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    CAUTION
    Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
    To avoid print quality problems, DO NOT touch the roller part of the toner. Try to keep you hands, fingers and everything else away from there.
  13. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the green lock lever will lift automatically.
  14. Open the front cover. Put the drum unit and toner cartridge assembly back in the printer.
  15. Put the paper tray firmly back in the printer.
  16. Close the front cover.
  17. Make sure that the Error LED is now off.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Jan 27, 2011 | Brother HL-2170W Laser Printer
PAPER JAM
give this a shot
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Apr 14, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Cannot clear paper jam on L7580.
give this a try
alternative :
Apr 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper jam
try this....
alternative :
Jan 19, 2009 | HP LaserJet 2820 Printer
Error paper jam
ellow bkadam,
there something little piece of paper stuck at you fuser there.that why appear paper jammed...try to open u fuser cover...maybe it can help
Nov 07, 2008 | HP LaserJet 2840 All-In-One Printer
Ricoh AC 104 copier
If the paper jam occured behind the toner cartridge, did someone pull it out and leave a piece behind the toner? Look to see if there is a small piece of paper jamed in the connector of the toner / developing unit. Also look for any small piece of paper in the paper path.
May 24, 2008 | Office Equipment & Supplies
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
OKI C5200n Laser Printer Logo
720 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Dominion Computer...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
