Question about Sony PlayStation Portable (PSP) Console
PSP sound ouput
Does anybody knows if the mini usb connector on the PSP (used for connecting to PC) can carry sounds output to let say a hifi equipped with a USB input connector (ie: using the psp as an mp3 player to connect to a hifi) or only the 3.5mm jack used by the headphones can carry audio out ?
USB output is preferred to avoid signal deterioration associated with jack to RCA connectors.
Thanks
Chris
  • chfandsa Dec 29, 2007
    I've got a mini usb earphones that I use with my PDA, so will try to connect to the PSP and find out if I can get any sound out of the mini usb connector. Does anybody knows if all pins from the mini usb are wired to the PSP ? This may explain a lot....
Ya Natahan you can use the usb to charge the psp only with the slim psp not the fat
Posted on Jul 30, 2008
  • 24 Answers
I'm pretty sure the USB port is only for transferring media files. I've searched my PSP head to toe and never heard of anything like that. I've found out you can use the USB connector on the white PSP to charge the battery. (I haven't tried that out yet.)
Posted on Dec 28, 2007
Where do I find the audio output on a Sony bravia tv
Hi John,
if you're using the HDMI cable then the sound will be carried via that cable along with the Video signal. If you're connected via RCA's the Stereo output will be the Mini-HIFI jack that looks like the earphone jack on most cell phones. The Bravia also has the option for Optical output.
Aug 11, 2017 | Sony Televison & Video
How to download games
1. CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
2. TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
3. EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
Apr 13, 2011 | Sony PlayStation Portable (PSP) Console
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
What do i need to play back recorded video onto my t.v from my sony handycam dcr-trv260...i have s cord, usb cord, yellow rca jack??? so what else do i need!!!...nothing i have tried has worked???please...
You can connect this camera to a suitable TV with either the S-Video lead or the RCA lead, but only if the TV is equipped with the appropriate inputs. The S-Video lead looks like a tiny DIN plug, and the RCA jacks are three separate plugs coloured red, white and yellow (yellow is composite video, red and white are left and right stereo sound). If you use S-Video you will also need to make a separate connection for sound (using the red and white RCA connectors). Sometimes the TV sound input is a mini stereo jack, and you will need a Y connector to adapt the two RCA connectors to the mini jack, or maybe the camera's sound output is also by mini jack, in which case you may need the reverse Y connector. Most TVs have some way of accepting a video signal, but you may already be using it for a DVD player or the like.
If your TV lacks these connections, you may be able to use an adapter. In the UK, most recent TVs have a SCART (Peritel) socket, which takes a big plug with 21 connections on it. You can get an adapter to fit that socket that will allow you to plug in the RCA connectors and maybe the S-video too. I don't know what country you are in, or what adapters are available in your country if it isn't the UK.
Once you have made the connections, you must select the appropriate input on your TV. The other possible hiccup is setting the camera to the right video standard, NTSC or PAL., to match that used by your TV.
The USB cord will not connect your camera to the TV.
Jan 11, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
When I plug my PSP (type A) into my PC (Windows XP
Make sure you follow these steps, this will allow the PC to recognize the PSP:
First make sure you have a USB cable that looks like this:
Then do this:
  1. Connect the mini connector to the top of your PSP and the other end of the cable into a USB slot on your PC. For the best perfornance, connect your PSP to a USB 2.0 slot.
  2. Make sure the PSP is on.
  3. Scroll to the 'Settings' menu by pressing the left arrow on the PSP.
  4. Select 'USB Connection' using the up and down arrows on the control pad.
  5. Press the 'X' button.
  6. Your PC should detect the PSP device, and show it in Explorer as a new drive (for example, 'F:').
Nov 28, 2009 | Sony PlayStation Portable (PSP) Console
How do i connect my psp to my pc
Use a USB A to Mini B connector.
Select "USB Connection" on your PSP and it will show up on your computer.
Sep 18, 2009 | Sony PlayStation Portable (PSP) Console
How to connect MHC-RG222 speakers to my pc
If you have an output function at the back of your mini HIFI then surely you can.What you need is a Dual RCA [from the mini HIFI] to 3.5 mm Stereo Jack [to the PC]. The cable is easily available in the market...go to this site n you'll get the idea http://www.vpi.us/cable-audio.html
Jun 17, 2009 | Sony MHC-RG222 CD Shelf System
NO SOUND - APOGEE & SPEAKERS HOOKED UP
possibly obvious... but on the maestro control / settings  meter display /output /input
Dec 02, 2008 | Apogee Ensemble Sound Card
How to use a usb cable for the psp
Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
Scroll to the "Settings" icon on the home menu of your PSP.
Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
After that you can now transfer file from PSP to computer and vice versa...
Hope that helps..............
Sep 12, 2008 | Computers & Internet
Hi..
try to connect to the right output port pf the sound card.
launch a music,test all available connectors so that you know which connector is for ouput.
pls also be sure that sound is enable or the driver is installed properly for sound effect
Apr 25, 2008 | Computers & Internet
Sony PlayStation Portable (PSP) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
