ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum.
I would also recommend that you remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Keep in mind how the belt is routed, this will come in handy later with you reinstall the drum and belt.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
SOURCE: do you have a digram to show you how to change belt on inglis dry
Diagram A
Style: Flat with ribs
Installation Tips: Ribs face toward drum
Diagram B
Diagram C
Diagram D
Installation Tips: Ribs against drum
Diagram E
Installation Tips: Flat side of belt against drum
Diagram F
Diagram G
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
Diagram H
Diagram J
Diagram K
Diagram L
Diagram M
