Philips 46PP9302 46 in. Rear Projection Television
Problem for Philips 46PP9302 46 in. Rear Projection Television
The bottom of the screen has an wave pattern of
By marshallbroo on Oct 18, 2009
The bottom of the screen has an wave pattern of discoloration and shows double. The picture is very difficult to see at times.
Best Solution
posted on Oct 18, 2009
Very Helpful)
JomasTech
Rank: Guru
Rating: 86%, 27 votes
your prism is off balance. it's like a shining a light into a mirror and point it into a specific spot. that mirror is out of sync, causing the image to move, which in your case it's a double image. the best way to fix this is to get a local repairman to fine tune your pic. again, the repair cost is between 200 to 400 bucks. just giving you heads up on that.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 29, 2009
Not Rated)
rgotro36
Rank: Apprentice
Rating: 100%, 3 votes
I believe your convergence IC's need replacing.
Was this helpful?
Yes
No
Solution #3
posted on Oct 31, 2009
Not Rated)
assistencia_
Rank: Wiz  Televisions & Videos  Expert
Rating: 78%, 53 votes
Check your antena cable, first.
Was this helpful?
Yes
No
Popular Solutions for Philips 46PP9302 46 in. Rear
Questions and Unsolved Problems for Philips 46PP9302 46 in. Rear
Do you recommend Philips 46PP9302 46 in. Rear Projection Television?
Answer
Answer
I have a phillips magnovox 9p6031 c103 rear projection tv. At first the screen would shrink and have... (More)
Answer
I found this46pp9302 46" rear projection TV at a yard sale but it has no remote. I already have... (More)
Answer
the green light on the front of my tv its on and off but dont turn on the tv and the light still... (More)
Answer
The color has separated, I have a purple and green shadow around all objects
Answer
problems with phillips 50pp9202 convergance on upper left and lower left screen red and greens... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
