Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Leaks My Hoover Steam Vac leaks.  Where the leak is is no immediately evident, but is is more pronounced when in upholstery mode.
  • Kathi Chamberlain Apr 06, 2008
    Leaks out bottom or unit, but the 3 hoses are not cracked. where else should I look?
  • Anonymous May 14, 2009
    Same Problem
    President:
  • 1,673 Answers
Check the end of the upholstery hose, it may be cracked.
Posted on Jan 10, 2008
I took my nozzle apart on my hoover steam vac because it leaked water all the time, now I cannot get the back together
The Hoover SteamVac is an upright, self-contained carpetcleaning machine. The machine features five rotating brushes and on-boardstorage for a hand-held upholstery tool with an 8-foot hose. But itis not that much difficult to re-attach the Hoover SteamVac nozzle. Here, a weblink, with full procedure and diagrams, which will help you to re-attach iteasily - http://hoover.com/file/624/. Hope this will help you. Good Luck.
Aug 18, 2011 | Vacuums
Hoover steam vac leak from the bottom when tank has water in it when not running but tank is not leaking
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Nov 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Lost Manual for Hoover Steam Vac Model #5906-900
Visit www.hoover.co.uk
There you can pick after sales service,instruction manuals, etc. etc.
You will find your manual there.
I hope this helps
May 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
555 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
