Question about Denon AVR-1400 Receiver
Denon avr-1404 Power turns on then about 3 seconds later, clips off.. everything in unhooked from it checked internal and fuses, this is as far as i got, any ideas.
    New Friend:
Has not helped after replacing of these regulators still same problem
Posted on Feb 08, 2013
Thank's, i'll try it
Posted on Feb 05, 2008
I got the same problem and on my AVR1404 it is the regulator
-15v (7915). You can control voltage on
R145 : +15v and
R146 : -15v.
The other side of these two resistances are joined together.
Good repair....
Posted on Feb 03, 2008
Denon 1909 flashing red ring after 20 minutes
Well on most models red ring singals :
1 ) speaker wires touching something they should not
2 ) internal overheating, shutting down to protect
3 ) something is wrong, bring in for service.
I'm guessing it's out of warranty?
Dec 25, 2013 | Denon Audio Players & Recorders
Denon AVR-4806CI won't turn on.
you must check first the fuse in the power supply which getting blown.if the fuse blown with darkened black color that was mean there are other component parts in the power supply or in the board which get bad. if you know how to test component, check shorted bridge type diode as will as regulator ic and FET transistor in the power supply board.
Aug 16, 2012 | Denon AVR-4806 Receiver
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
Denon AVR-687 cannot power on, no power light lit around power
Check the main power switch next to the large power button. It is a small push button. If it is pressed in and you still have no light around the power button then very likely you have a dead power supply.
Apr 27, 2010 | Denon AVR-687
Hi My denon avr 2600 keeps clips when turn on
Check the polarity (+/-) of the speaker wires. A typical receiver will try to cut the power to the speaker if it's feeding it too much power or too little power to preserve the speaker and/or receiver. That may be the clipping you're hearing. If the wires are reversed, this can cause the same thing.
Aug 15, 2009 | Denon AVR-2600
DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Jul 21, 2008 | Yamaha RX-V461 AV Receiver
Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Jun 27, 2008 | Denon AVR-1705 Receiver
Power won't stay on
This could be a major problem in the power transistors or closely related. Recommend service by a technician
Apr 19, 2008 | Denon AVR-1507 Receiver
My Denon AVR-887 Keeps turning itself off
I have one and the same thing happened. try resetting your microprocessor and if that does not work, then check the wiring of the speakers. if that is working fine and no wires are touching then I unplugged everything and was still having the issue. took it in for service and it was found that the transmitor was shorted as the speakers that I was using was too high in ohms. it is possible that it could be your caps also if resetting the microprocessor does not help. You can find out how to reset the microprocessor from your manual. If you have the Denon avr 887 with the system turned off hold the power on button and the speaker A and B at the same time for a few seconds. This is compatible to rebooting your computer. Hope this works for you as this was and is my husbands favorite past times.
Dec 01, 2007 | Denon AVR-887
778 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
