Replacement capacitor information
32" JVC TV - AV-32F703 capacitor blew in location C973 on main board. Don't know what size to replace with.
  • 41 Answers
There is a wire jumper labeled W624. You will find a ring crack around one leg. This caused C973 (10mfd50v) to explode. It also takes out D432 (NTE519) and Q431 (NTE2416). It can also take out C432 and if C432 (47mfd25v) is bad it probably also opened R449 (8.2K SMD).
Posted on Feb 18, 2010
32'' jvc tv- av-32f704
capacitor blew in location C973 on main board. I FOUND THE SHELL AND IT WAS COMPLETEY BLOW OFF ITS A 47MF AND 25VOLTS. I WILL REPLACE IT WITH A NEW ONE YET THIS SEEMS AS A COMMON PROMBLE. iS THE POWERSUPPLY BAD
Posted on Feb 26, 2008
    Problem Solver:
  • 72 Answers
It is safe to replace the capacitor with the same ratings.. you can visualize the blown capacitor at its top portion., remove that capacitor and buy same rating written on its body.. voltage and the capacitance.. usually written as 300V and 3300mF.. when returning it, please take note on the diretion,, + and -.
Posted on Dec 30, 2007
I have a JVC TV AV-21DTG2 the TV goes on protection mode as soon as I switch on the mains power
The power supply regulator section circuit has to be troubleshooted. There might be some shorted component/s. It is a skilled work. You must have sound knoledge in electronics to do this work.
Apr 24, 2012 | JVC AV-32D305 32" TV
I have a 32" tv jvc iart and horizontal white
Hello
You are seeing vertical retrace lines. This faut is due to the vertical output section inside your TV. To rectify this fault, you must open your Tv. Just open it after unpluging it from the wall power socket. Locate the vertical output section on the printed circuit board.
It is easy to locate. You can see four wires goes from the deflection yoke; the coil fitted around the neck of the picture tube. Out of which two of them will be thick, usually red and blue coloured, and the other two will be thin. These two thin wires are for vertcal scanning. Just follow these two thin wires, and you will reach a point where these four wires are pluged onto the main circuit board, very near to the LOT. Upside down the printed circuit board, and follow the print of that two thin wires, and you will reach to the vertical output section of your Tv.
Before doing anything, just look for any loose soldering or bad solderings there. It is very difficult to find out loose solderings, as thay will be microscopic, I advice you to resolder most of the soldering points there by applying a little more solder; without making any solder short. Resolder all the pins of the vertical output IC, and see the effect.
If this does not help, replace the two or three electrolytic capacitors, at about 1000MF to 2200MFD there, with same capacity and voltage ratings. Make sure about their polarity, as electrolytic capacitors have both positive and negative terminals like torch cells. Note the polarity when resoldering them out of the board. This must solve ypur problem.
If you need anymore asistance, feel free to contact me through Fixya. OK
Wish you sucess.
Dec 11, 2010 | JVC AV-32F703 32" TV
I have a JVC AV-32F703 tv just replaced the vertical IC tv comes on but immedeatly goes into shut down mode by what could the problem be? Retrace lines was on top of picture before it started going into...
Chances are you should have checked some components related to that IC,namely an electrolytic capacitor.They tend to leak or short.That IC burned for a reason.
Sep 25, 2010 | JVC AV-32F703 32" TV
Our JVC AV-32F703 has a black screen when we turn it on. The sound works fine. What could it be? The tv was purchased in Jan 03
try up the screen bottom in the fly back. if yoy see a white horizontal line the tv have a cold solder in vertical ic or is bad.
Apr 14, 2010 | JVC AV-32F703 32" TV
AV-32F703 has redish flare upper right corner. Is
bulb problem. needs to be replaced. the tv looks a little old maybe yu need a new v for once.
Feb 17, 2010 | JVC AV-32F703 32" TV
Burned up capacitor on JVC TV
It is a 1n5 500V and is sat across the main 135V supply rectifier D921.
Replace both!
Sep 20, 2017 | JVC Televison & Video
JVC AV-35750 TV
I changed capacitor C926 (1000Uf 16V) on main board. It solved the problem. I went with 1000uF 63V as it was readily available...it's okay to go with higher voltage. It was hard to fit it on because of the larger size but it worked.
Jul 28, 2008 | JVC AV-35750 35" TV
Bad PS component - C921
Here is a picture with the part in question.
Jun 20, 2008 | JVC AV-32920 32" TV
JVC AV-36260 TV Problem TV won't turn on
  • blowing fuse is a short circuit problem in your tv.
  • please do not replace fuse unless you know the reason otherwise it may damage tv.
  • fuse blowing is due to
  • main filter capacitor
  • power output transistor sort or regulator short circuit.
  • good luck
Oct 21, 2007 | JVC AV-36260 TV
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
