Question about Vivitar ViviCam 3750 Digital Camera
Vivicam 3750 I left the batteries in to long and there was some corrosion. I cleaned it up and put fresh batteris in and started it up. It powers up but just beeps. I think it is a series of 4 beeps then pause. It shows me no screen.I can temp stop the beep by pressing the mode switch.I have opened the camera and cleaned it. It was very clean with nothing apparently wrong. Can you help me. or is it fried. Thanks for reading. Tim
Do you live near salt water the salt in the air will seep into and under protected spaces look a little closer using a magnifying glass
Posted on Jan 17, 2008
Hi, I have two IC-R10's in very nice condition. Previous owner passed away several years ago and left the rechargeble batteries inside the units(The contacts had very little corrosion left from the...
  • Hi, I can help.
  • It is very possible that the corrosion could be a little worse than initially thought. Look for unnoticed corrosion and clean the contacts real real well with a pencil eraser.
  • Under the third battery is a switch marked (Charge) OFF/ON. When using the power supplies to power the scanner the switch should be off (pushed to the left). When using batteries the switch should be turned to on (pushed to the right)
  • The internal charger is meant to charge Ni-Cad batteries not Alkaline batteries. If you have Alkaline batteries in the unit then you should never have that switch to on with the power cord plugged in or a charge will be attempted on the Alkaline batteries and they will explode/leak.
  • The problem will be that switch, unnoticed corrosion or the batteries you are using are not good.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Icom IC-R10 Handheld Scanner
The camera doesn't turn on. I used it, put it away and when I go to use it again, nothing. What could be wrong?
What type of batteries? If Ni-Mh then just recharge them...
Some cameras draw off a little power to keep the internal clock going so maybe the batteries
got discharged.. or if alkaline just try a new set of batteries
Jan 23, 2011 | Vivitar ViviCam 3750 Digital Camera
My camera won't turn on. I put in brand new batteries straight out of the package and i put them in to the camera and it sttill won't work. i hold the power button for about 10 seconds. Not working.
AA batteries can be placed in the camera the wrong way around. They can also cause corrosion of the battery contacts if left in for long periods or run down. I would check these two things before assuming a fault.
Oct 25, 2010 | Vivitar ViviCam 3780 Digital Camera
Vivicam X30 Problem
This is most commonly caused by dirt/grit or a power problem.
Try turning the camera lens down and blowing compressed air from a can (keyboard cleaner) or compressor into the area between the lens and the camera. Once you finish the cleaning, hold the zoom button in and power the camera on.
If the above doesn't clear the problem, make sure that your battery is fresh and fully charged. If the battery is more than a year old it probably needs to be replaced.
Finally, check and clean the contacts on the battery and inside the camera's battery compartment. Corrosion builds up on the contacts, especially if a camera is unused for a while, and it's not always visible. Wipe the contacts firmly with a clean dry cloth to remove light corrosion - a heavy buildup may require cleaning with a fine wire brush, steel wool, or sandpaper. After the cleaning, place the battery back in the camera and give it good charge.
HINT: The battery cleaning also works for cell phones, PDAs, laptops, and other items that use rechargeable batteries. Always check it before you chuck it.
If none of the above work, your camera probably has lens damage that will require a professional repair.
Bill B
Bill B
May 20, 2010 | Vivitar ViviCam-X30 Digital Camera
How to i copy all pictures to memory card on vivicam 3750
Loading pictures from usb to computer
1. Put your flash drive into the usb port of your computer.
2. Click on Left Click on Start and Left click on My Computer.
3. There will be a new drive letter, more than likely E:\.
4. You can copy multiple copies or single copy by clicking on one
picture then you can hold down Control key and select the ones you want to copy.
5. Leave the mouse on the last picture you selected, then right click,
and tell left click on copy.
6. Go to your local drive C:\ and if you want to make a new folder to be
organize, and click on that folder and right click and tell it paste.
Dec 20, 2009 | Vivitar ViviCam 3750 Digital Camera
When camera is turned on it suddenly powers down
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 29, 2009 | Vivitar ViviCam 5340s Digital Camera
My vivicam 5022 turns then beebs twice and like falls asleep
If this response helped, please post a rating for me. A rating of "Very Helpful" would be appreciated . . .
Nov 25, 2009 | Vivitar ViviCam 3705 Digital Camera
I have a ViviCam 3650, I put new lithum batteries in it, turned it on I get a red light but nothing else
Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 12, 2009 | Vivitar ViviCam 3650 Digital Camera
Camera turns on and then right off immediatly
first if u want to get ur cam to work use energizer rechargeable batteries after charging them for sure this is the best kind u can use powerful and last longer ,to get ur pictures out u can take memory off the cam and put it inside memory card reader then plug it to ur computer through usb ,computer will read it easy and u can download ur pics to ur pc
Mar 27, 2009 | Vivitar ViviCam 3750 Digital Camera
Vivicam 3750
I had the same problem and formated my disk. Now the camera works fine. You will lose any pictures taken previously.
Jul 13, 2007 | Vivitar ViviCam 3750 Digital Camera
Vivitar ViviCam 3750 Digital Camera Logo
35 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
