Question about Sony Cyber-Shot DSC-F505 Digital Camera
Flash problem Flash doesn't work, it gives an error message . Thanks
0 characters
1 Points
Err CF I have a Canon Rebel XT, how do i fix this error and what does it mean?
CF stands for compact flash which means you have an error with your memory card. Try removing and replacing your compact flash memory card. If that doesn't work you may need to format your memory card or replace it.
Jul 28, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Flashing E 91:01
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Thank you !!
Jun 27, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
What does E:91:01 mean? I get the error message when I turn my camera on and the flash will NOT work. Please help. Thanks,
e:91 is the purticullar flash failer error itmeans you may chang flash unit please go to your nearst sony service centre & fix your problum
Oct 08, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I get an error message, E:91:01 blinking ,I can't find Reset bottom under LCD cover
It's flash error. Could be a dead flash fuse on the main board or bad flash board. Contact your local Sony service center, but if they ask too much, you can contact me at and I will give you a good price.
I work in Sony service center.
Jul 12, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flash doesn`t work
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!!
rate me!!
May 29, 2009 | Kodak EasyShare DX7630 Digital Camera
Flash won't work and flash setting cannot be changed from menu
This is eather caused by a bad flash circuit or a bad mainboad. Repair cost around 65.00 to 75.00 to repair.
May 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Moultrie gamespyi40 error code 020000
I just spoke to the moultrie techy about the same error message I have with my i40, This is a false positive message, the i40 uses infra red instead of a flash; the self test is testing for flash and giving the false error. This was an oversight by Moultrie, no down-loadable patches are available to correct this at this time
Jan 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Flash Error
The error 5 can mean that there is something blocking the flash from popping up. If it is up but still get the message then you need to check to see if the little black pin/stick that lets the camera know that the flash is up, is not stuck. With the flash up and pointed at you ( like you are going to take a picture of yourself) the pin is located on the right side close to the where the flash attaches to the camera. Yo should see a little pin sticking up. make sure that area is free of dust and /or debris. if it is not up then that is the problem. try to free it with out braking it or get it professionally repaired.
Jul 08, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Guys - I just recevied a new H9 today. Was using it and decided to turn the flash off. Later on I wanted to turn it back on and I got the famous "flash settings cannot be changed" error message. I found the problem. I had turned on the "continuous shooting" option as I wanted to see how fast it would take photos continuously. When that option is on, you cannot use the flash so therefore you cannot change the flash settings. I put the camera back in "single-shot" mode and now the flash works fine. I hope this fixes your issue.
Thanks, Ken
Nov 23, 2007 | Sony Cyber-shot DSC-H9 Digital Camera
Camera does not flash
problem is with the high voltage capacitor charge circuit. the internal battery voltage is stepped up to around 4 thouseand volts. this voltage is necessary to jump the electrode gap inside the xenon strobe tube which is the flash component
Sep 02, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony Cyber-Shot DSC-F505 Digital Camera Logo
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
