Question about OKI KIT-C3530N MFP LASER CLR P/S/C/F USB ENET 1200X600 128MB Printer
Error 1005 trying to fax
We are getting this error code on our confirmation report of NG <1005> and we cannot recieve or send faxes...
  • MTAngel Jan 15, 2009
    I just purchased the C3530N and am having the same problem. It was working for a few days, now I receive a fax every once in a while, but sometimes the receiving ones even get denied.
5 Suggested Answers
Riztech
  • 731 Answers
SOURCE: Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Posted on Feb 09, 2008
SOURCE: I don't want fax receiving confirmation report it waste my paper.
Go to menu (wrench)
Arrow down to Reports - OK
Arrow down to Fax Reports - Ok
Hit Ok at Fax Confirmation
Select Never and hit OK
Hit Cancel when done and it should now not print confirmations.
Posted on Jan 15, 2009
SOURCE: Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Posted on Jul 30, 2009
  • 97 Answers
SOURCE: OKI 5550mfp Fax Problems
error 209 - Media Table Download Failure MediaTable Download to PU failed. Reboot.
CU firmware detected an anomaly in behavior in PU (including a violation of communication protocol between CU and PU).
are you suing unusual sized paper?
Posted on Mar 29, 2010
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
report lists the time and date of transmission and whether the transmission was successful
(OK). If you choose On or On+Image, the report will print for every fax you send.
If you send a lot of faxes to the same place, you may need more than the job numbers to
know which faxes you must send again.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
to help you remember.
When the Transmission Verification Report is turned Off or Off+Image, the Report will
only print if there is a transmission error, with NG in the RESULT column.
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Mar 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Is there a way for me to leave a date/time stamp when sending a fax on my intellifax 1940CN?
if you enable send report you can get an a4 page with time and date confirming that the fax has been sent, but when set up it will print for every fax. the other option is to have it print on error only and you can manually print report of sent recieved items( all date and time stamped) with the number sent to as a list.
Aug 10, 2009 | Brother IntelliFAX 5750e Laser Fax
Confirmation
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Confirmation print out
Your wanting what Brother calls a Transmission Verification
Report:
You can use the Transmission Report as
proof that you sent a fax. This report lists the
the transmission was successful (OK). If you
When the Verification Report is turned Off or
Off+Image, the Report will only print if there
RESULT column.
a Press Menu, 2, 4, 1.
b Press a or b to choose Off+Image,
On, On+Image or Off.
Press OK.
c Press Stop/Exit.
Nov 11, 2007 | Brother MFC 240C All-In-One InkJet Printer
OKI KIT-C3530N MFP LASER CLR P/S/C/F USB ENET 1200X600 128MB Printer Logo
273 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Dominion Computer...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
