That noise usually means that the belt is worn or stretched and its slipping on the motor shaft. Replacing the belt is easy to do and you can get the belts for this model here:
I just need to get one cleaned and a wheel the other. Is there a store in cr i could go check it...
(More)
I just need to get one cleaned and a wheel the other. Is there a store in cr i could go check it out?
We had a store i used all the time in DSM. Just want to find one here
Electrolux Oxygen Upright 5035: Shut down after 5 minutes of normal cleaning with hose. Power to...
(More)
Electrolux Oxygen Upright 5035: Shut down after 5 minutes of normal cleaning with hose. Power to switch OK with Fluke Tester. Neither vacuum motor or the brush elevator works.(2 different switches)
Bissell "CleanView" bagless upright vacuum cleaner. The foot operated handle release...
(More)
Bissell "CleanView" bagless upright vacuum cleaner. The foot operated handle release spring/tang is broken. There is no replacement listed for this part on the Bissell website and, without having taken the bottom off, there appears to be no direct method to remove this par even if I did have a new part.
Any insights are greatly appreciated!
