New psu for Shuttle XPC SB81P won't work!
Got a new power supply for Shuttle sb81p. Will not power up! Upgraded from the 350 to the 450. Plug it all in, and it's just dead........any suggestions would be appreciated.
  • MissKaren92 Dec 29, 2007
    The PSU definitely works, but the fan spins only for a second when we switch the power switch on the back of the computer; then it's dead again.
    If anyone can give a breakdown of what connects to what just to make sure we have it connected correctly, it would be greatly appreciated.
    We are replacing a 350 with a 450 ps55 upgrade kit.
    Thanks so much for your help.
  • onebuffchink Feb 26, 2009
    I have a similar problem with my SB81P except I can start it by pressing the reset button. Not sure if a power supply problem or motherboard problem. Any solution?
  • 90 Answers
Try these:
Remove the PSU from the case.
Plug it to power.
Turn it on
Using a paper clip, short circuit the green wire pin with the the black wire pin on the 24 pins connector.
If the PSU fan start, remove the clip. The fan should keep spinning. That means that the PSU is working.
If the PSU is working, then the power up pins on the mother board might not be shortcircuited by the front panel switch.
Connect the PSU to the motherboard and to the power, turn it on. On the motherboard, locate the power up pins and short circuit them with the paper clip. If the computer powers up then there is a problem with the power on switch.
If the PSU does not start at all, return it.
If you can't return it, unplug from power, open it (warrenty voids!) and look for a fuse that looks like a one inch glass tube with metal caps. inside should be a wire. If the wire is broken, buy a new fuse in Radio Shack.
Hope that helps.
Posted on Dec 28, 2007
Reset cmos, doesn't switch on
Plug out your pc, hold the power button for a few seconds and then take out the battery. Then wait a few minutes and put the battery back in. This should reset your cmos. If this doesn't help then the problem might be a corrupt bios, defective psu, faulty cpu or memory.
Mar 17, 2014 | Shuttle Computer Shuttle Xpc Sn78sh7...
My shuttle boots up for half a second, then shuts down. I have removed, HDD, RAM etc, but makes no difference at all. Any ideas?
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Sep 15, 2010 | Shuttle XPC 250W Power Supply (CSSHMIS10)...
I need to replace my shuttle sb81p motherboard but dont know where to buy the exact one the rest of the pc is fine thanks in advance.
This is a custom board, you could get one only directly from Shuttle (with very little chances of success since they discontinued this model 4 years ago) or from an site dealing in second-hand items.
Jun 08, 2010 | Shuttle XPC SB81P...
It don't start up, it means not light, no fan's no nothing
try a different kettle lead...
then try powering up with the motherboard disconnected...
if still no dice then new psu....
Nov 02, 2009 | Shuttle XPC PC Desktop
Need a schematic for achme power supply model am630bs20s
Do NOT open a power supply!!!! Proceed with caution: When finding a new power supply, make sure the voltage is the same and the amperage is less than or equal to the original power supply.
Sep 28, 2009 | Shuttle SS51G XPC Mini PC System (MSS51G)...
SB81P Not powering up, fan pulsating?
Are you sure all your cables are hooked up correctly on your flat ribbon make sure the wire with the red line is in the #1 position. If this is correct try disconnecting the cable and power and it see if the problem goes away.
Mar 21, 2009 | Shuttle Computers & Internet
Can you replace a XPC Shuttle power supply with iStarUSA CP01040?
I did exactly the same for a build I did for someone, but I used the PSU that Shuttle suggested which of course is one of their own, but those boxes are so cramped that a centimeter out will ruin your day.
Depending on which model XPC you have I'd advise you to get a Shuttle SilentX 450W. If you click here you can see which models it fits and all of the techs and specs you need.
Best price I could find it for in the UK is here but also found one in Canada for just over £70. You can see that one by clicking here.
Nov 19, 2008 | Maxdata iStarUSA CP-01040 400W 1U...
Shuttle XPC XB51G Barebones - no power
I think you will find your PSU has gone faulty, they are very cheap these days, I would guess at the PSU and replace it "On Spec" with a similar one. Remove the four PSU screws around by the Fan at back. Unplug it from The motherboard noting connections, can only go one way thogh. Take the PSU to ya local repair shop and get another... put new one in connect up to MB and power up. If ya lucky.. ya solved ya problem. Or better still see if you can test it with another one B4 buying another.
Aug 08, 2007 | Shuttle XPC 250W Power Supply (CSSHMIS10)...
Computers & Internet Logo
784 people viewed this question
David Payne
David Payne
