a power supply problem. It sounds like set is turning off because
the power supply is not regulating properly. I would suspect you have a few
Capacitors in the regulator circuit failing. for
first unplug the main power cord of the tv for couple of minutes and then
reconnect it.also before reconnecting the power cord of the tv again remove all
the external device wires connected at its back such as dvd player/vcr etc
etc.just connect only tv wire and check out.if still the same problem then its
quite possible that the capacitors and ic on the circuit board are getting
short in between so the circuit is not getting completed and cutting in between
so the power comes to the tv but the light blinks in this case the circuit
board needs to be checked with a multimeter.the faulty and burned out component
part should be detected and then should be replaced with the help of soldering
iron.to make it proper.to avoid further damage i suggest you that do not on the
tv again and again as it will short some more tiny components and the reparing
cost will increase as per that.at present its the normal circuit short problem
in the tv get it repaired before using the tv again This will help. Thanks please keep updated.please do rate
the solution positively .thank you for using fixya.
can not get ps3 to work on 50h72 toshiba tv i can get hd satelite to work but not dvd or ps3 and...
(More)
can not get ps3 to work on 50h72 toshiba tv i can get hd satelite to work but not dvd or ps3 and tips or advise ? when i get it hooked the the sound is great but the video is scrambled i can see the actual menus but blurry and scrambled
When a bulb goes on a projection RCA 50 inch tv, does it just get dimmer or do they just go out...
(More)
When a bulb goes on a projection RCA 50 inch tv, does it just get dimmer or do they just go out completely? Thanks
When I play a dvd it does not hold a solid picture. I have changed dvdv player and cables to no...
(More)
When I play a dvd it does not hold a solid picture. I have changed dvdv player and cables to no avail.
I'm having the same issue with my Toshiba 50H72, constantly flickering, like a power problem,...
(More)
I'm having the same issue with my Toshiba 50H72, constantly flickering, like a power problem, however, it almost completely clears up when I switch the input to a HD input. Any idea what I can do to fix it? Is there some part that I could replace to fix this? I don't want to buy a new set yet, if it's a minor repair. Thanks, Larry
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
