Question about Watches
Timex expedition 100wr
How set time and date?
SOURCE: timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Posted on Jun 02, 2008
SOURCE: adjusting my timex expedition cr2016
For CR2016, press and hold the SET lever for atleast 10 - 20 secs. Push the mode button until the hours value blinks. Use the 'ALARM ON' lever to adjust the time. Use the mode button to move from hours to minutes and repeat the same steps. Push the SET lever to set the time once all the required fields are adjusted.
Posted on Jun 03, 2008
  • 2992 Answers
SOURCE: changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Posted on Mar 11, 2009
  • 2071 Answers
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Posted on Jun 08, 2009
  • 2334 Answers
SOURCE: I have a Timex analog Indiglo watch and need to change the date
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
Posted on Mar 28, 2010
  • 831 Answers
SOURCE: how do you set the time on a timex wr50m watch?
Posted on Jul 23, 2010
0 characters
1 Points
How do i set the time on a timex Expedition T49949
Hello. You just have to pull and turn the crown found in the 3H location of your watch. Normally for timex watch with date function, you have to pull the crown on the 2nd pull position or until the hands move when you turn the crown.
Mar 10, 2015 | Timex Mens T49949 Expedition Digital CAT...
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
May 28, 2011 | Timex Expedition® Metal Field 47042...
Lost my manual. Need help setting date, time, alarms and so forth. Timex Expedition T41101
Welcome to FixYa!
Here's the link for the instructions you are looking for
It is in PDF file. Make sure your computer has and Acrobat Reader installed.
Thank you for using FixYa.
Have a great day.
Apr 28, 2011 | Timex T41101 Metal Outdoor Expedition...
I need an owners instruction sheet to learn how to set dATE & TIME.
You can get instructions from the Timex web site "".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 06, 2011 | Timex Expedition Perpetual Calendar...
If you have the crown in the first click position (date set position) the date set wheel is most likely damaged. Otherwise, if it does not change in 24 hours, it is the date wheel itself that is damaged.
This happens in all watches over time, as even quartz watches must technically be serviced every 3-5 years. 90% of manufacturers quote this as the standard service rate for quartz and mechanical watches.
If this watch has sentimental value, and you will want to contact a local Certified Master Horologist or Certified Quartz Technician about replacing the movement. Replacing Timex movements is generally more expensive than purchasing a new watch.
If the watch is still in warranty, you may consider contacting Timex about replacing the watch free of charge at:
Feb 04, 2011 | Timex Expedition 43892 Wrist Watch
Change day but not date on Timex Expedition
  • Step 1 Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
  • Step 2 Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
  • Step 3 Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
  • Jul 28, 2009 | Timex Expedition Outdoor Athletics Watch...
    Need setting instructions for date,alarm,etc on my timex expedition
    Here is the link for all Timex watches and the appropriate manuals.
    This should provide you with the information you require, if you have an issue not covered there I will try to find you more specific information.
    May 26, 2009 | Timex Watches
    Adjusting my timex expedition cr2016
    nike T20 lap digital sport watch? Older model. cannot adjust time, date, etc. Know where to get instructions?
    Sep 25, 2007 | Nike Super WR0064405 Wrist Watch
    Watches Logo
    53 people viewed this question
    Top Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
