Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Having problem in recovery of my laptop
I hav a toshiba A135 series laptop but i m not able to get my recovery drive in that means its not visible,when i checkd in computer management i has an extra drive wich is not visible otherwise but that drive is only of 1.46 GB n without any label n type of file system.
now i m not able to get if its my recovery drive or not coz 1.46 GB contains my recovery of vista,howz that possible?
tell me what to do?
  • 90 Answers
You have to have a recovery CD.
The partition contains information that would help recover your system and is used by the recovery CD.
Posted on Dec 28, 2007
How to restore a toshiba satellite a135-s2286 notebook without cd?
the f8 function is only to try and remedy boot problems. the recovery option you're getting is to restore if you have already made recovery discs.
if you have a recovery partition on your hard drive you should be able to access it when you boot up. before starting your laptop press and hold 0(zero) key and power on the laptop. once it starts you should get a screen with 3 options then choose option 1 to get back to factory restore.
Nov 11, 2012 | Toshiba Satelite A135-S2286 Notebook
Im helping a friend fix their toshiba a305-s4527 laptop running windows vista and they need the recovery cd, i cant find it online and i told my friend when i find it i would link it so she could buy it
In most cases this is only available from the Toshiba Website through the Software update section. Because the software is Toshiba specific and will not install on a machine other than Toshiba in that series. Now, having said that, if you did not wipe out the partitions on that hard drives there is a recovery hard drive on that laptop. This is how they distribute software now. You can usually access the recovery system by pressing and holding the F10 Button right after you push the on/off switch. This will access the recovery menu and allow you to restore the system to it's original factory settings and drivers. If this option no longer works you will have to go through the Toshiba Software update section to purchase the recovery disk. Here is the place to start:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?modelFilter=A135-S4527&rpn=PSAD0U&category=&selCategory=2756709&moid=1700045&os=&ct=DL&selFamily=1073768663
Copy and paste this link in your browser and it will take you to the update section for the laptop you identified.
Aug 08, 2011 | Toshiba Satellite A135-S4527 Notebook
Replacing the dvd room drive? any ideas
Toshiba Satellite A130, or A135 series of Notebook PC, I do,
Removal guide,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
Remove the one Philips head screw in the Ram Memory Compartment, Step 4 and 5.
http://www.getpartsonline.com/k000045560.html
(Also have seen a lot of listings on Ebay)
Regards,
joecoolvette
Jul 30, 2011 | Toshiba Computers>Laptops Satellite A13 PC...
How do i wipe my toshiba satellite a135 with my 2 disk recovery/drive app disks?
Place disk ! into the DVD drive and turn the laptop on. It will boot into recovery mode and just wait for the prompts.
It will restore your laptop to its original state.
Hope that helps.
Nov 10, 2010 | Toshiba Satellite A135-S2276 Notebook
I have a toshiba satellite laptop A135 series and it won't recognize my toshiba external hard drive. However, the drive works fine with my HP
This can be an issue with the USB port, or the drivers.
Is the hard drive a Power HDD ? that means it has 2 usb chords one for power and one for data transfer? coz those might not work with laptops, also has it ever worked with the laptop ?
Thanks
If this was helpful, then kindly rate me.
Nov 10, 2010 | Toshiba Satellite A45-S121 Notebook
I have a toshiba A135 Laptop and the cd/dvd drive has stopped working. if I boot from my toshiba system recovery disk via the cd/DVD drive.. How will I know if the drive can be restored to normal...
if you are able to boot from the recovery media then you can justify reimaging the system as it would seem that it is a software issue. backup your files beforehand and you should have no problem.
Oct 26, 2009 | Toshiba Satellite A135 Notebook
The recovery on my Toashiba Satellite A130/A135 doesn't work
Try to boot the machine in safe mode by pressing F8 as the computer starts up, if will let you boot into safe mode as it sounds like there could be some bad sectors on the drive causing it to hang on boot.
To check this right click on the C drive and select "properties", then select "tools" tab, in the tools option check the volume for errors.
This can take some time to perform so please be patient.
If you can't get the machine to boot into safe mode please post back
Jun 22, 2009 | Toshiba Satellite A130 A135 Notebook
All drives xp for Toshiba Satellite A135-S4527
Ok just to clear the question up... I you just installed a new HD in your laptop and have already downloaded your recovery cd that came with the pc then you are asking for the remaining drivers that you are missing... if so here is what you need to do. If you are not missing your internet driver go to www.driveragent.com this requires a yearly membership of I think 29$ This will scan your pc and give you the drivers to download. If you just installed a new HD and if you turn your computer on and get nothing this is because you did not install your recovery disk,,, if you do not have your recovery disk ONLY Toshiba can provide this and you can order it from them. I would also call Toshiba for your driver disk as well if you cannot get on the internet...
Jun 12, 2008 | Toshiba Satellite A135-S4527 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
