Question about Protron PD-DVR100 DVD Recorder
Cannot access setup menu
I have tried holding the enter button but it still comes up as INI ETAIL
  • Anonymous Aug 24, 2008
    I have the identical problem with the same Protron PD-DVR100 DVD Recorder.
If you are trying to go through the coax input and output it won"t work because the output is just a passthrough. You must output through the RCA'S or S-video.
Posted on Jan 21, 2008
Gave mine to salvation army for an electronics tinkler to play with and maybe they will get somthing for my mistake?
Posted on Dec 31, 2007
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
How do i turn the safety lock feature OFF that my son somehow managed to turn on?
Thanks for the information.
If there is a key symbol illuminated on the display, press and hold the "LOCK" button on the Zenith remote. This is located near the bottom of the remote, near the REC/ITR button.
For the parental lock feature, press the SETUP button on the remote then use the UP/DOWN arrow keys to highlight RATING and press the RIGHT arrow once. This will open the rating menu. Press the DOWN arrow repeatedly until UNLOCK is highlighted then press ENTER. Finally, press SETUP again to close the menu.
You may be asked to enter a password to change the rating setting. If you know the password (4 numbers), enter it when prompted. If you don't know or you've forgotten the password, close the menu using the SETUP key, then press SETUP again to re-open the menu.
Dont select anything here, simply press 2 1 0 4 9 9 using the number keys on the remote and then press ENTER. This will clear any password that has been set. You will then be asked to set a new password the next time you try to access the RATING section of the menu.
Please try the above. If you get stuck at any point, post another message here and I'll get back to you immediately.
Regards,
BElectric
Mar 06, 2011 | Zenith XBV442 DVD Player/VCR
Trying to setup the Panasonic PTL 720U, accidentally turned off the control key to OFF in the menu and now cannot access Menu or another other options. How do I reset back to factory or so I can access the...
In order to set the CONTROL KEY to "ON" without
using the remote control unit, keep holding down
the ENTER button on the projector and press the
MENU button for more than 2 seconds. It will then
be turned ON.
Feb 12, 2011 | Panasonic PT L720U Multimedia Projector
Can the service menu for the LG 52sz8d dlp tv be accessed from the orig remote not the service remote just installed new lamp and tv was working fine for 1 week now the lamp indicator light comes on and...
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Hope this helps. Regards, James.
Apr 22, 2010 | LG 52SX4D 52" HDTV
Lg hotel tv. t.v. button are locked out, only hotel remote works
Hold down the MENU button on the remote for approx 5 seconds. Then enter 1105 this will access the hidden hotel option on the LG tv so you can change whatever you like..
Cheers LITTLE DISH FITTER
Jun 08, 2009 | Televison & Video
Sony PCS-1 dont remember admin password
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
Pioneer SD-P50A5-K 50 inI
Hi, I am just curious. What is going on wih the Television? Thanks, Mike
Nov 04, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
PCS-1
Reset password sony pcs-1
PUSH ENTER button).
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
Tried the 543210 code but no menu appears , am i missing something
In order to acess the hidden menu you first have to first click the AM/FM button then on youre remote click the dvd setup button once there press 54321 listening to the beeps. Then hold 0 untill the hidden menu comes up
Dec 29, 2007 | Jensen VM9510 Car DVD Player
TURN OFF PROGRESSINE SCAN ON ZENITH XBV443
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 16, 2005 | Zenith XBV443 DVD Player/VCR
Protron PD-DVR100 DVD Recorder Logo
80 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
