I learned that my CA software was not operating properly because I still have Norton anti-virus on my system. CA support told me to uninstall Norton and reinstall CA. I downloaded the Norton removal tool but was unable to start the uninstall because I apparently still have leftover files on my system from an aborted install of winfax pro. The Norton removal tool instructed me to uninstall winfax pro before proceeding, but all attempts to do so have failed. I downloaded symclean from norton, but it failed to remove it. I downloaded ccleaner, but it failed also. I even removed all winfax files and data from the registry and temp file, but the norton removal tool continue to tell me to remove winfax pro. I called norton tech support, but they no longer support winfax. So I'm stuck.
When I am in the send fax screen, I have three prblems:
1. My default cover page has text with...
(More)
1. My default cover page has text with inserts in it. When I view the cover page on this screen, the text seems to be in two layers. One layer has the variable inserts (@C, et al). The other layer has the text as it will display when I open the annotation screen. How is this corrected?
2. About every 4 times I send a fax, When I add attachments, I get a general default error and I have to close out of Winfax. I have to go to task manager and manually exit the three services that are running. Frequently, the WinFax controller is in on the task bar (lower right side) in duplicate. How is this corrected?
3. I want to insert a logo on my cover page. When I do this, I can only see the graphics object that is cross hatched, but the logo is not there. Is thier a problem with doing this? Is their a file size or file density limit for these types of graphics?
Just installed WinFax 10.02. I can't get WinFax to initialize. At the CSID screen, it immediately...
(More)
Just installed WinFax 10.02. I can't get WinFax to initialize. At the CSID screen, it immediately drops out.
When I attempt to open Winfax pro, the message manager screen never fully opens and the hour glass...
(More)
When I attempt to open Winfax pro, the message manager screen never fully opens and the hour glass remains constant. The same is true with ACT 4.0
