Question about De Dietrich 24 in. DVF120J Built-in Dishwasher
Wont switch on
All the lights work on the panal so it gets power, but the button to turn on the dishwasher wont work
Try replacing on/off button or replacing the door switch.
thees parts sould be examind by technishian befor replacment.
Posted on Dec 21, 2008
Turn on ignition and no power to ignition switch or insterment panal but have head and tail lights batttery good
First check if the ignition switch is getting power-either through a maxi fuse in your under hood fuse/relay box, or a fusible link coming from a battery source.
Jan 18, 2014 | Chevrolet S 10 Cars & Trucks
Dishwasher won t turn off
As long as you have wired up correctly, your new board is faulty.
If you mean wont power down, as in the lights on the front wont turn off, these lights and the power switch itself are all part of the board.
Take it back for a warranty swap. Occasionally there is the odd faulty new part, there has be some unfortunate person to get them.
Jun 01, 2013 | LG Dishwashers
Drawer wont slide and dishwasher does not work
please provide the model number of the dishwasher so that I can identify the type of lid seal it is using. Usually the lid seal actuator motors are stuck and prevent drawer from opening. You could force it open with a slight tug. Otherwise turn the mains power off and on and see if it makes any difference. Need to check the lid seals for damage otherwise it may leak in future and cause flood switch to trip.
Dec 07, 2012 | Fisher and Paykel Dishwashers
My kenmore dishwasher wont start at all now. It used to start if you pushed certain buttons a bunch of times but now the lights next to most of the buttons light up but it wont start a cycle. any ideas?
Hello
Ensure that the dishwasher is connected to a working power supply. Check the local fuse or circuit breaker and restart as necessary.
Open and shut the door firmly until it latches into place. The dishwasher will not function if the door is not latched into position.
Select the desired cycle and press the cycle button firmly, as you must choose a cycle in order for the dishwasher to begin operation.
Look at the water valve that is connected to the dishwasher and ensure it is turned on.
Turn off the dishwasher and unplug it from the power supply to reset the unit. Plug it back in and select a new cycle. Select "Start." If the dishwasher still does not start, contact an authorized service technician.
Sep 11, 2011 | Kenmore Dishwashers
DDW1802W ran fine yesterday. Panel light os, no start. Door seems to latch okay. It's not an overflow switch issue. No burnt smell.
dishwasher wont turn on. power is ok. when you turn the dial with the power switch on it clicks motor turn on pumps do not turn on wont fill or empty power light does nnot light up latch seems to be fastening proper is there a reset switch
Apr 09, 2011 | Danby 17 in. DDW1802W Designer Series...
Dash lights out
check the instrument panal fuse. if ok check and be sure if tail lights and etc are working.if they are working and still no panal lights, it maybe there is no power going through dimmer switch. see if power is going to switch. if not coming out of switch it is bad. the wheel where you dim the lights has a rheostat inside and it may have given out.Check your headlight switch. Sometimes the switch goes bad and the dash lights won't light. Replace the switch for the fix. if not the dimmer switch is bad.
May 20, 2010 | 2000 Chevrolet Malibu
POWER ON-PROGRAM WONT WORK
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Frigidaire dishwasher
When my wife got home, she told me where she put the manual. After reading it, all you have to do is press the rinse button for 3 seconds and the lock light will go off. I am not going to take off any electrical panel.
May 31, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Midea dishwasher WQP12-924OA wont go alarm sounds when turned on and than the second light flashes
I had the exact same problem with the exact same model. It sounds unlikely, but I couldn't get it to work until I clipped the drain hose into one of the clips 2/3rds of the way up the back.
There was a sticker there that said "the drain hose must be attached to the left or the right clip"
Jan 29, 2008 | Dishwashers
De Dietrich 24 in. DVF120J Built-in Dishwasher Logo
349 people viewed this question
Top De Dietrich Dishwashers Experts
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
