Question about Toshiba Satellite M35X-S111 Notebook
My laptop has died!
Yesterday I was using my Toshiba Satellite M45 laptop, with near-full battery and wired cable. Suddenly it all went black. When I tried to start it up again, nothing happened (not even after waiting for a while and then pushing the start button for 20 seconds, as suggested by Toshiba): the battery light and power light did not come on.
Today I have tried switching it on again and the laptop came to life for about ten seconds, only to die again.
I have tried again since, with and without the battery and with and without the cable, in all possible combinations.
I have not had a chance to try a different battery or a different cable yet, but googling around it seems that the possible reasons are:
the battery is dead
the cable is dead
the laptop has overheating
the fan needs cleaning
the motherboard has become dislodged.
Before I go to a repair shop, can somebody advise me if there are other possibilities (so I know what to ask) and what the best course of action is.
Thanks a million.
  • 111 Answers
You are correct in these possible reasons, but there is one you didn't list and that may be that your BIOS for some unknown reason has been damaged, unfortunately you can't get the computer to power on long enough for a post test to check the BIOS. The best advice I can give you, is if it's still under warranty to call Toshiba and talk to a service tech and ask what they think might be wrong, they might have a solution to the problem or they will just have you send it in and repair it at no cost.
Hope this helps
Posted on Dec 28, 2007
TOSHIBA SATELLITE M45-S165 won't charge Battery. The power connector on the back of this laptop is losse but still powers the Laptop. I bought a new battery and the Battery light does light up on the front...
it could be possible that changing the dc jack at the back may fix the problem however it could be a faulty new battery as ive had a few copies (not original) which would work for a week or so then die or others which wouldnt work at all, i finaly splashed out on a new original battery and it hasnt let me down and i bought it over a year ago.
Hope this helps
Apr 19, 2010 | Toshiba Satellite M45-S165 Notebook
Where is the cmos battery in a toshiba m45 s165. I have looked for the red and black leads and don't see them. I really didn't want to completely disassemble until it's the last resort.
Yes silverdragon is right. I just disassembled my m45 to replace the cmos. It appears to be soldered. There are no red and black wires though. You must disassemble.
Jan 29, 2010 | Toshiba Satellite M45-S165 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Having problems reassembling a Toshiba M45
You didn't mentioned which two wires you have problem with, so i found detailed Toshiba Satellite M45 dismantling instructions.
Just scroll down (then page2, page3. ...) and find your wires and what to do with them.
Aug 28, 2009 | Toshiba Satellite M45-S165 Notebook
My M45/S331 doesn't start nomally
its happen because you left it and it was overheat pls take care your laptop work or keep in cool place while working.
Jun 10, 2009 | Toshiba Satellite M45-S331 Notebook
Laptop suddenly shut off and will not turn back on
Sometimes the voltage regulator in the battery hit a point where they fall below a certain efficiancy % they have to operate at. Once they fall below that % you must replace them, even if the battery is 100% charged. Its usually a good idea to pick up a new charger as well with a new battery since they are known to die as well. Make sure you check the socket in the back where your charger plugs into the laptop to make sure its not loose or cracked. Sometimes the plug will crack off the motherboard and not make good enough contact.. But regardless of that it should atleast turn on if the battery was charged and good. Best bet, new battery. Every 2 years you should get a new one.
Jun 04, 2009 | Toshiba Satellite M45-S269 Notebook
Toshiba satellite m45-s169
with the operating disk you can repair a windows installation( system files ) and not lose any saved data(files)
Oct 08, 2008 | Toshiba Satellite M45-S169 Notebook
Toshiba M45-S331, Black screen
I just went through all this myself. First I had the inverter replaced ($200) and it worked great for a week, then the screen went out again. It turned out that the LCD needed replaced ($200 more, labor comped from the first no-fix). There's a problem with the Toshiba LCDs that makes them burn out sooner than other brands. Since the replaced screen, no problems (2 months). Sucks, I know.
May 07, 2008 | Toshiba Satellite M45-S331 Notebook
Locating the cmos battery in a toshiba satellite m45-s165
If you have disassembled your toshiba unit, and you are somewhat new in electronics, you cannot see the battery similar to other PC, bcoz its battery is somewhat soldered, and the only things you migt notice is its two colored wire (black and red) attached to a round, flat, insulated (wrapped with insulation) battery.
Dec 17, 2007 | Toshiba Satellite M45-S165 Notebook
Screen display has gotten smaller.
Well this is unusual & interesting.. (sic)I can still see the entire window(sic) I wonder if somehow the Display Drivers have gotten Screwed up.. Try un-installing your graphics hardware Drivers,then re-install the latest Drivers for your system. Of course B4 ya do any of that try adjusting your windows display to any other resolution and see if this changes things.. Below is a helpful link...
Aug 21, 2007 | Toshiba Satellite M45-S351 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
