Question about Rockford Fosgate P3001 Car Audio Amplifier
Stuck On Thermal Mode.
So I got the P3001 hooked up to 2 Rockford P2 12's. My amp is flickering Thermal but the amp isnt hot. Even when I unplug the subs its still in Thermal mode. Sometimes it will catch and the subs will hit for a minute but after that nothing but some popping sounds. Someone told me that the amp could be shorted out inside. Any Help?
  • niggnogg Apr 12, 2008
    my amp thermal light only comes on when disconnecting the groung wire,all the time with no power going to my amp.
  • hungerunger Jun 16, 2008
    my thermal light stays on and my amp does nothing. when i take out the fuse shouldn't it turn off? it stays on. if possible... could anyone tell me wat i need to fix? i dont have warranty so im fixing it myself. i changed a mosfet because the other one was fried. as far as i know the mosfet is working fine since its not glowing red and the connections of the power sparking when i connect the power to the amp. the thermal light just comes on. i already tried disconnecting all other wires except for power but still nothing. just thermal. i wonder if its just the ic between the two fets or because i glued it with epoxy to the heat sink. maybe it sends current through it? i need help please!
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still remains in thermal protection, the amplifier likely has an internal fault and will need to be repaired.
Posted on Dec 29, 2007
I just installed a new xo vision x349nt dvd receiver in my car . My rockford fosgate p3001 amp turns on but the subs doesnt come on but when i would take the base control out and put it back in i can hear...
Make sure and check the RCA wires in the back of your radio that send audio to the amp and make sure that they're connected to the OUTPUT/SUBS RCA's and not an input rca's. Also, check your ground and make sure no speaker wires in the subs are shorted. Try one speaker at a time see if that helps.
May 18, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
P3001 problem
if amp is mounted to back of the box try and move to in front of box near subs or port. the air movement of the sub will help keep the amp cooled. or you can orer some 12v cooling fans and take back plate of the amp and cool it that way. or you can buy higher quality audio, your choice
Feb 20, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
My amp wont give me any power
all the p series amps were discontinued for similar problems, they have a newer model out now. they have very weak boards internally and failed faster when mounted to the sub enclosure or very close to it from subsonic vibration. i would guess the amp is toasted.
Dec 17, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Amp turns on but doesnt power my subs
well ill need 2 know wat knobs are all on the front of your amp
Nov 07, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
RF P3001 power problems
check your sub woofer connection if you have multiple subs the could be wired in a parallel or with has to many ohms that my cause it to not hit right and cause the amp to get really hot and cut in and out
Nov 15, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate P3001 Car Audio Amplifier Logo
684 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
