I have a Phillips projection 53inch Model 54Z915 7903. USA made 1998. When turned on there is no...
(More)
I have a Phillips projection 53inch Model 54Z915 7903. USA made 1998. When turned on there is no sound or picture only a green screen with curvy lines thru it. I know how to solder etc... I fix washing machines and dryers generally. Any advice on repair and parts needed would be greatly appreciated. Thanks Dave.
I have a Phillips 46PP9302 Rear Projection HDTV. Last night, it appaeared that the blue gunbriefly...
(More)
I have a Phillips 46PP9302 Rear Projection HDTV. Last night, it appaeared that the blue gunbriefly went out and the set lost convergence on the red and green. Then it just shut off. I waited a couple minutes and attempted to fire it back up. The power light came on, but there was never any picture, and then it shuts of after about a minute. I tried leaving unplugged overnight, and then trying again int he morning, but its the same. Any ideas? Should I even bother calling for a repair or should I just go after one of these LCD deals?
when plugged in and turned on no picture and makes a chirping noise when unplugged the noise slows...
(More)
when plugged in and turned on no picture and makes a chirping noise when unplugged the noise slows and quits like a fan rubbing against something but no picture and no sound
My Sony Grand Wega kf50we610 takes like 10 times to try to power on before it actually turns on and...
(More)
My Sony Grand Wega kf50we610 takes like 10 times to try to power on before it actually turns on and works. What could the problem be? It's not the lamp because that is replaced. It will click like it wants to turn on but goes back to blinking red. It will finally turn on after many tries but I'm sure it won't be long before that doesn't work either. :( Any help would be appreciated.
