Question about Toshiba TDP P5 Multimedia Projector
Hello. i have tdp-p5 and when i turn it on, it light's on, but it doesn't show the usual background. it show's nothing besides the light from the lamp, and then it restart over and over... can you help me? "sorry my english"
  • 2,239 Answers
You need to replace the main board. sorry.
Posted on Nov 11, 2009
SOURCE:
Orange light blinking when turned on and doesn't project picture
First check your manual for trouble shooting the lights meaning. I think it is the bulb.
Jan 10, 2013 | Toshiba TDP T1 Multimedia Projector
Toshiba TDP-P5, used unit. Startup image comes up ok. When PC is hooked up, the image does does not change from startup. Cables test okay on other projectors, the video port on the PC is working ok on with...
Try pushing the source/select button to make the projector look for a source. It is the button that looks like a bent arrow right in the middle of the 4 arrow buttons.
Jan 14, 2011 | Toshiba TDP P5 Multimedia Projector
We have a Toshiba TPB P5 projector that displays all menus, and shows the computer display fine at first, but as soon as the video changes (new page, new window) the projector shuts off and goes to...
First check your video with ANOTHER external monitor. It may be the video output of the computer turns off (It often comes from a different driver than the main computer screen). This would then be a software problem...
Jan 09, 2010 | Toshiba TDP P5 Multimedia Projector
My projector lamp turn on about 2 then turn off. light bulb haves
the power supply needs to be replaced. if you're good at soldering, there is a capacitor that dries up quickly on the ps board. i believe it's c2.
Nov 09, 2009 | Toshiba TDP-S8 Multimedia Projector
My projector makes a really annoying noise
It is also possible that the bearing is going bad on the fan. I'd look into getting a replacement fan if that's the case. It is probably cheaper than a replacement bulb that would be needed if the fan failed entirely.
Jul 09, 2009 | Toshiba TDP-P5 DLP Projector
Z4MPLUS P3/P5 ERROR I found some problem in Zebra Z4m plus printer like error p3/p5.please give me solution for that
The display shows P3/P5 ERROR? You can try to load firmware, download the file from www.zebra.com press the keys - and +, turn the printer and you see FIRMWARE DOWNLOAD in screen, download the file through the parallel port.
Roberto Martinez
Jun 01, 2009 | Zebra Z4Mplus Label Printer
Will not turn on at all
you will probaly needs a new power supply in it. make shure that your getting power from outlet to. Hope this helps
Jan 13, 2009 | Toshiba TDP-ET20U DLP Projector
Displays desktop background but nothing else
I discovered that my laptop supports two monitors and the projector was acting as monitor #2. By changing the priority of the monitors I have got the information I need on the screen, but now not on the laptop. However, I can work the two from the screen and that will suffice for the moment, until I can find a way of getting the information on both!
Sep 05, 2008 | Philips bSure SV1 Multimedia Projector
Projecter not working
I have this same problem with no indication of what is wrong with the projector. I have checked the bulb and see no lines (veins) or bubbles on it.
Jul 20, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-P5 projector
Possibky is overheating... I would put a fan on it and see if the time-to-fail changes,
Oct 03, 2007 | Toshiba TDP P5 Multimedia Projector
Toshiba TDP P5 Multimedia Projector Logo
152 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
