Question about Whirlpool Duet GHW9150P Front Load Washer
Door Lock Whirlpool Duet front loading washing maching. I keep getting the DL F error code. Door lock failed. Bought the new door lock ... came in the mail - no directions. How do I find directions to install the new door lock? nancy.thoma@ht.msu.edu
  • mdlclu Jan 22, 2008
    I think I have narrowed it down to two identical relays on the main board, one in position k4 the other k1 does anyone know which one it is. Others have replaced the relay. This would of course solve the bad solder problem also. HELP thanks Mel
    Genius:
  • 1,554 Answers
I took the motherboard out and searched around for the crack with a microscope, I found that every one of the relays had bad solder joints with micro-cracks around the legs. This did not happen due to wear or vibration. It was just a bad solder job on the factory wave solder machine. QC issue.
After re-soldering all the relays legs I have run the machine for a month now without any issue.
So there it is the final fix for the dreaded door lock F dl issue. and likely any other random issue.
Posted on Jan 21, 2008
  • Karl Whisenand
    Karl Whisenand Jan 25, 2008
    don't worry about which relay it is. because they both serve the door.
    Just re-solder (refresh) the joints solder joints. and you will fix the issue.
    Note: The offending cracks are very hard to see without a microscope or eye loupe.
    Problem Solver:
  • 19 Answers
Check out this website recomment before replacing any parts
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Posted on Mar 02, 2008
  • 36 Answers
Well thats a good one lol if you take off the top or bottom panel i beleive its the bottom theres a manual in there that may help you in a plastic bag be sure to put it back when your done
Posted on Dec 28, 2007
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control panel displaying DL F and not starting
The door locking routine fails to lock the door after six attempts the the error code FdL flashes to indicate a failure in the door lock and switch assembly. The only viable solution is replacing the door lock and switch assembly. Click on the link below for the instructions in replacing the door lock and switch assembly.
Replacing the Door Lock and Switch Assembly on Whirlpool Duet Front-Load Washers
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Duet front load washer door will not lock. I
Sounds like you have a door lock failure due to the fault code you have or it could be a control brd failure. Sometimes if either fails it will blow the other aswell.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashes "DL" and "F"
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't start flashes dL then F
or lock failure. Probably a bad wax motor. get ahold of your authorized dealer. This is a defect on these machines. They have a new and improved wax motor. Raise enough hell and they will fix it for you.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer
F/11
Serial Communication Error
Communication between the Central Control Unit (CCU)
and the Motor Control Unit (MCU) cannot be sent correctly.
Check Wire Harness connectors to the MCU, the motor, and-
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
F/dL
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked.
Check the wire harness connections to the Door Lock/Switch-
Feb 23, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Try everything else, like reseating the connectors, then look here:
http://adsisecurity.com/KenmoreWasher.htm
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
144 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
