Question about Zhone (6218-I2-200) Router
Paradyne 6218-I2 ip filter
How can i activate ip filter in paradyne 6218-I2 firewall? i only able to isolate PCs with mac , but i want to be able to isolate them with ip filter too, it seems that ip filter is not working however my firewall is enabled!!!!
  • redfox750 Dec 29, 2007
    same problem
  • redfox750 Dec 31, 2007
    no DHCP Is disabled , i use 192.168.0.2 , and 1 for gateway , the problem is in the if filter itself , may be something in telnet config we don't know about!
  • 61 Answers
If you are using multiple computers, and DHCP, then your IP's are probably changing, which is causing your issue. You need to manually assign an IP to a computer for the IP filter to be effective in the Paradyne.
Posted on Dec 31, 2007
  • Dion Miller
    Dion Miller Dec 31, 2007
    If this is unclear let me know
  • f_munroe
    f_munroe Mar 29, 2013
    how would i go about doing this?
Paradyne 6218
The router must provide new internal IP's. Make sure it is set to DHCP. IPs are never shared.
Mar 29, 2013 | Paradyne (6218-A1-200) Wireless Router...
Need to change the NAT setting on my Zhone 6218 DSL modem. How?
try these simple steps...
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection through control panel > network connections.... if you get the ip adress in the range of dlink router then try going to start > run > type "cmd" and hit enter >command prompt will appear... in command prompt type this
start iexplore(default gateway address) and hit enter...you will see the settings page of your modem.... go ahead and disable firewall and enable dmz for your ip address... also forward the ports that are necessary for your gaming device...
Jul 16, 2010 | Zhone (6218-I2-200) Router
Changed the IP address on Zhone 6218-I2, can't access browser UI.
Go to start -> run -> cmd.
When the window comes up, type: "ipconfig". The address that says "Gateway" should be the address of the router.
If that is too confusing, try the following combinations:
192.168.0,1,
192.168.0.254,
192.168.1.254
192.168.2.1
192.168.2.254
May 23, 2010 | Zhone (6218-I2-200) Router
My paradyne has no IP ADDRESS, HOW DO I PROGRAM THE IP ADDRESS INTO WINDOWS 7
start menu
-search programs and files
-run
-cmd - enter
-ipconfig (press enter)
-you'll see defult gateway, thats the ipaddress of you paradyne.
Apr 25, 2010 | Paradyne (6218-A1-200) Wireless Router...
What is the Username and password for model:6218-I2-200-0CC
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
IF you still not able then press RESET button it is in back side of router press it for 10 seconds then follow the above instruction .
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 10, 2009 | Zhone (6218-I2-200) Router
Paradyne 6218 12 200. With dynamic IP address, this modem/router will assign addresses to both fixed all 4 ports, and wireless laptops. How do we program it to do the same when ISP has assigned a static IP...
If desired change the IP address or Gateway will please right click the name (My Network Places), then right click (Local Area Connection), (Properties), have at the bottom to select, high light the name (Internet Protocol (TCP / IP), Lift Click the Properties, to trim after you customize IP add and modify the following required.Good Luck
Jul 23, 2009 | Paradyne (6218-A1-200) Wireless Router...
ZHONE 6218 unable to connect
Try to configure you router with WPA authendication. provide some encryption password,if asked. Then configure your lifebook with manual ip by wifi adapter ->network settings-> tcp/ip properties - > specify manual IP something like 192.168.1.2 Now try connecting to your router.It should ask for network key and will connect if key provided matches with the one configured.
May 21, 2009 | Zhone (6218-I2-200) Router
Paradyne 6218-12-200 won't connect all computers
A public IP address is usually assigned to the WAN port (outside/public side), which is how your router is conected to your Internet provider service.
A private IP is always assigned to the private network side (LAN = Inside). Unless you are hard coding your IP addressing on each of your devices, you will need to have DHCP enabled in your router with enough user IPs for your devices (more than 1).
Apr 11, 2008 | Paradyne (6218-A1-200) Wireless Router...
Zhone (6218-I2-200) Router Logo
287 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Awesome12
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
