Question about Emerson EWR20V4 DVD Recorder/VCR
Burner will not format a disk
Buy a new machine...seriously! if u have the same machine as i have, the only disks that will work are dvd -rw 1x-2x (next to impossible to find since technology has soared way beyond those fossils).
Posted on Jan 06, 2008
Format.....
To format a hard drive, You can simply use the Fdisk command from DOS -
C:\fdisk
This will bring up a list of commands and useage.
You can also use the format command from within DOS -
C:\format c:
This will prompt you "all data on disk C will be lost, are you sure?"
Type 'Y' and hit enter.
From within a windows/linux/unix environment, you can right click on the disk you'd like formatted and select "format".
From within Mac OSX, open disk utility, and select the disk you'd like to format. Click on "unmount disk". Once unmounted, you may format the selected disk.
Hope this helps.
Jul 18, 2012 | Gateway Computers & Internet
When i want to open my D drive ,it gives this masage 'the disk in drive d is not formatted. do you want to format it? yes or no' . i don't want to format it. what shoud i do?
As you know already that format disk basically creation of FILE ALLOCATION TABLE (FAT) NTFS (new technology file system)
it is necessary to store data on disk. but if this error occurs while disk already formatted with any file system then simply run disk repairing utility to fix the problem
If its intel based machine or AMD and running windows then i would recommend run scandisk utility
if its mac run disk utility from utilities and check disk for any error and it will repair the disk
good luck
Aug 19, 2011 | Computers & Internet
Will not format, in disk manager when I partition it it gets to 100% while formatting then it says format not complete. when i try to open it it says I This Disk has not been formatted, would you like to...
After writing on 100% of the disk-drive, the FORMAT goes back and tries to write on the FIRST few blocks of the disk-drive. When it cannot successfully write to the "start" of the disk-drive, you get the "not complete" message.
The only way to fix it is to responsibly recycle the old disk-drive, and purchase a new disk-drive.
Jul 08, 2011 | Computers & Internet
When i try to run a disk it says the disk is not formatted do i want to format it now. the disk has information on it so it has to be formatted .
It is possible that there are errors on the floppy disk or the disk was formated using a format that is incompatible with the current operating system. If the disk is readable on another system, the best solution would be to copy the files onto a portable USB flash drive, then reformat the floppy disk using a filesystem that is readable on the desired computer.
Apr 22, 2011 | SmartDisk USB Floppy Drive Titanium...
It is not formatting., please help me
hi
follow these instructions
Instructions Things You'll Need:
  • Windows installation media (and product key)
  • Manufacturer software
  1. Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
Nov 28, 2010 | Computers & Internet
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email ejaz89@live.com
Aug 06, 2010 | Computers & Internet
Disk has no format
Does the disk show up under My Computer? If so then right-click it and select "Format Disk" and format it in NTFS. If it does not view this link and follow the instructions to get that disk active...http://support.microsoft.com/kb/309000
Jun 05, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
How can i format my laptop
Step 2
Step 3
Step 4
Step 5
Step 6
May 06, 2010 | Computers & Internet
How do i format my packard bell easynote
Hello
  1. Step 1 Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Step 2 Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating systemmag-glass_10x10.gif floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Step 3 Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Step 4 Determine which file system is to be used. Windows XPmag-glass_10x10.gif will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Step 5 Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Step 6 Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
  7. Hope this can help you, kind regards, andrea
Nov 13, 2009 | Computers & Internet
Hard disk problem
First u should format disk from disk management mmc snap or from command prompt.without formatting a disk's properties says 0 bytes used and 0 bytes free space.
Sep 03, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Emerson EWR20V4 DVD Recorder/VCR Logo
44 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
