Question about Garmin StreetPilot C330 GPS Receiver
Charging My 330 recharges well on the computer but when pluged into the car I get a low battery warning after about 4 hours. Changed the fuse in the power cord to no avail, car lighter does work, and unit turns on and off with the ignition switch, sometimes.
  • 3 more comments
  • Anonymous Jan 07, 2008
    me too
  • Anonymous Jan 09, 2008
    my garmin 330 shows low battery, how do I charge my gps
  • acm563 Feb 09, 2008
    I have this same problem and have no idea how to charge my 330. The only time I ever see the battery charging icon is when I just now hooked it into my pc but that went off as well so not certain if it is charging or not. All other garmin products I have owned have charged via the car charger so I cannot understand why this does not work with the 330
  • lindar Mar 31, 2008
  • rollie70 Apr 03, 2008
    My 330 recharges well on the computer but when plugged into the car I get a low battery warning after about 4 hours. Car lighter does work, and unit turns on and off with the ignition switch, sometimes.
    Purchased at Thanksgiving & has worked well until recently. Charges well from computer but not from car lighter in either car. Anyone have a "working solution" ?
The same thing just happened to me today. It was working fine for over a year. I usually charge it in my car. But last week I charged it using my computer, and since then, it doesn't get any power from the car charger.
Posted on Mar 25, 2008
  • 174 Answers
"unit turns on and off with the ignition switch, sometimes."
There is something wrong with your power cord or the connection to the cigarette lighter. Your unit should turn on and off with the ignition switch. If the unit is on and doesn't turn off with the ignition switch then your unit is running on battery. If your unit doesn't turn on with the ignition switch then the unit is not getting power from the cigarette lighter.
Posted on Jan 11, 2008
How do I recharge the battery tried replaceing the fuses but it will not charge
the charging fuse on these is internal inside the battery box
1 carry out a continuity test in this blade fuse for open circuit
2 while open check battery volts is over 11 volt or scooter will drive=o/k if lower will need batteries replaced.
3.make sure your charger is the correct one for this scooter
as go go chargers conector are wired different .so a standard mobility charger wont charge these,as there will be no 24volt at pins 1 and 3 ,
Jan 15, 2015 | Pride Mobility Products GoGo Elite...
Medion NoteBook :LT 9886 The "Battery
The battery is shot and needs replacing.
Jun 30, 2008 | Medion Computers & Internet
My battery is every morning empty. Changed the dynamo, battery, steering contact. After removing the fuse of the radio / amplifier, battery keeps on level. Unplugging amplifier with fuse in results in low...
Have battery/alternator checked. Really clean connectors and battery posts even if they look ok. If battery is ok have it slowly recharged for 12-24 hrs. Alternators are not designed to recharged an empty battery but just to maintain the full charge. I large amp and sound system demands a big battery and heavy duty alternator.
Aug 04, 2013 | Cars & Trucks
Hello . i bought a used 2001 saturn s series. everything was fine , the car doesnt nstart.the battery light is on the dash board p[lus "service engine soon and oil pressure light.i already changed...
First thing you need to inspect the battery.The battery warning light is coming,due to battery is low on charge or battery got weak.If the battery is low on charge then get it recharged.But if battery is very old,then get it replaced.The battery and turn signal problem are two different problems.
Turn signals not working are due to faulty hazard switch/Turn signal switch,or faulty flasher unit.But in some cases its due to faulty turn signal fuse located in the interior fuse panel.This possibilities needs to be checked.Keep updated for further help.Thanks.Helpmech.
Jan 05, 2012 | 2002 Saturn L-Series
My philips gogear 4g is pluged in and works but when i unplug it it says low battery and shuts off immediatly it has been left on for 4 hours now trying to fully charge it will not charge is the battery...
If the media player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 26, 2011 | Philips GoGear ViBE Digital Media Player
How many hours do i charge my battery dor dsc t20 camera?
You can charge the battery of the Camera for 4 to 6 hours when used initially. For normal full recharging, it takes, 330 minutes. The practical charge time of the battery is for 270 minutes.
Thanks for using FixYa.
Jul 17, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
Once the unit is charged how long does the battery run dry
Once fully charged, it will last for about 4 hours, if it is used without shutting down. The good thing is that it comes with a rechargeable lithium ion battery. That can be recharged once it is weak. I will strongly advice that you do not allow the battery run down completely before recharging as the battery might become weak and unable to hold a charge. So do not let your gps die before recharging. you can charge once it is low.
Dec 24, 2010 | Nextar X3-03 Car GPS Receiver
Not starting looking for reasons. dash lights come on and cd player stops for no reason. Last time car started it died right a way then did'nt start again. I changed the starter and the battery is nearly...
it realy sounds like you have knocked the battery flat try to recharge it for a fuw days on a home charger off the car if poss if not poss that should still charge up but it takes a little longer to fully recharge the battery up but it will take at least two or three dayes to fully recharge it the way to work it out how long it should take is this,,,a 40amp hour battery will take 10 hours to recharge at 4 amps thats its max charge too?
or devide the amp hour by 10,,,ie: 60amp takes at 4 amp =15 hours charging,,,but it can be charged at 6 amps then its only 10 hours,,, i know,,,boring huh?
Jun 29, 2010 | 1997 Pontiac Grand Prix
Battery dead unless pluged into computer. Charges
Friend, the power switch is damage thats why the charger acted as switch. replace the power switch
Jul 17, 2009 | Sony NWZ-E436F MP3 Player
Garmin StreetPilot C330 GPS Receiver Logo
135 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
