Question about Whirlpool LGR3624JQ Gas Dryer
Hotpoint electric dryer
Takes clothes extremely long to dry. when I open the door steam comes out instead of heat. happened after the dryer was pushed up approx 2 feet to clean underneath.
  • 262 Answers
Check your vent its probably clogged or kinked you need air flow to get rid of the steam
Posted on Dec 29, 2007
Hotpoint WDF740G Dryer not Very Hot
Most likely to be either that the capacitor is defective which starts the motor slowly at first and then picks up speed or the drive belt is worn, usually this happens when the drum has clothes in it otherwise it looks as if it is operating normally
May 22, 2014 | Hotpoint Washing Machines
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
My whirlpool electric dryer WED5560SQ0 takes an extremely long time to dry, almost like it steams
it defne sounds like one or more of your heating elements is faulty , try a simple continuity test on them
Feb 12, 2012 | Whirlpool Dryers
The Hotpoint Dryer shows sweat on the inside door and takes longer to dry the clothes. Marilyn
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Dec 26, 2010 | Hotpoint Dryers
My general electric dryer DDE5300 is no longer warm so clothes don't dry, though it runs. How can I tell if its the heating element or the thermostat?
You Will have to use an ohm meter and the tub has to be taken out. You can on a GE open the door and push in on the door switch and starte it with the door open and look straight in and see the heater come on but if either the heat element of thermostat is out the element wont come on. If you live in ahouse with fuses instead of circuit breakes or a fuse box between the dryer and main circut box check the fuses an electric dryer will run on one fuse but not heat if this is the case switch the fuses and see if it runs if not one fuse is bad.
Apr 21, 2010 | Hotpoint NVL333EY Electric Dryer
Long time to dry clothes
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
Mar 09, 2009 | Hotpoint NVL333EY Electric Dryer
Kenmore 90 series not drying.
remove the ventin from behind the unit you need to replace and or clean your vent !!!!!
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Hotpoint washer dryer not drying clothes
Sounds like you have a ventalation problem. The clothes heat up, but without airflow, the moisture remains. First check the hose from the back of the dryer to the wall. Is it plugged, kinked, or restricted? No? Turn your dryer on and remove the hose. Do you feel pressure coming from the back of the unit? No? You need to take it apart and clean the internal airway. If you do feel pressure, reconnect it to the wall and start your dryer. Walk to the outside of the house. Do you feel a fair amount of air coming out? No? There are companies that will clean your vent in the phone book. There are also vent cleaning brushes you can buy at hardware and appliance part stores.
Jun 18, 2008 | Washing Machines
Steam comes out of dryer after cycle and door is opened
Probably has a restricted vent. Go outside with dryer running and check air coming out vent. Should be a good blast...not just a breath. Clean out the vent and make sure it's not kinked. If it vinyl or foil vent, replace it! Also make sure lint screen is cleaned everytime.
Nov 16, 2007 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool LGR3624JQ Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
