Question about Acer AL1714 17" LCD Monitor
Acer al1714 ive recently got on of these and ive plugged it in but nothing comes on, the computer and monitor is switched on but the monitor remains black. can anyone tell me some likely solutions pls
The problem may not be the monitor. Acer AL1714 is known for its weak power supply unit. Unplug power supply from monitor. If the green light on monitor comes on but goes out quickly, the power supply is the culprit!
Posted on Jan 04, 2008
My laptop Gateway ml6720 has a black screen Ive replaced the battery and power adapter no change. The fan comes on and it sounds like it boots up but no screen.
Sounds like either the screen or the video adapter has gone bad.
Do this: Connect the computer to an external monitor (there is a SVGA plug on the side of the computer. Be sure when you turn it on that you press teh Fn-special function key combo that switches the video output to the external monitor. If the external monitor works, then it's your computer's screen. Possibly the inverter. If the external monitor shows nothing, then it's the video card (which may be built into your motherboard).
Oct 05, 2011 | Gateway Computers & Internet
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
It won't turn on -
hi there, it sounds like your monitor isn't receiving power, check the power cable in your monitor is connected and not partially unplugged. Second, if that doesn't work, try looking at your plug and make sure that is plugged in. If that doesn't work, you may have to buy a new monitor or give it to a friend that can repair it.
Jan 19, 2010 | NEC 1760VM (Black) 17" LCD Monitor
My Hanns.g monitor 1080P HDM1 has a power problem, when it's turned on either by the power switch or when it's activated by the keyboard, it flashes on & off several times & then goes off, playing...
nfleurat, If nothing wrong with the "on"/"off" switch, then must be the "switch-mode-power-supply"/"CCFL inverter supply" circuit card inside of unit. Look for a possible "thermally intermittant solder connection" and then resolder it. Also, inspect unit for possible "swollen" electrolytic filter capacitors on power supply board. Read more of my responses to other owners in my FIXYA profiles for more options you can use to solve your LCD display problem. 12fixlouie aka louie12fix Good luck on the repair.
Jan 05, 2010 | Hanns.G Corporation Computers & Internet
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
Monitor remains black when on
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware (internal electronic part/s) is having trouble powering up the panel/ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring the unit to an authorized service center to properly diagnose & fix it. regards
May 22, 2009 | Acer AL1715 17" LCD Monitor
Computer monitor screen remains black
try giving the monitor a hot slap or spank at the back, believe me, you'll be surprise, you've got nothing to loose
Jul 20, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Lcd monitor failure
your monitor need to be service so take it to service center if you are in mumbai you can call for service
Ashok
9322133048
Nov 11, 2007 | HP Compaq FP5315 15" LCD Monitor
My monitor remains black
well your screens broken mate the only thing you can do is get a new one
Sep 30, 2006 | Amptron CMV-922D 19" Monitor
Acer AL1714 17" LCD Monitor Logo
258 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
