Question about Yamaha HTR-5730 Receiver
Composite Video hook-up question
I am trying to get the best out of all my equipment and am re-hooking everything up. I have a DVD recorder and a DISH satellite DVR box. Both of these have Fiber Optic Audio connections (which will hook up to my HTR-5730 receiver). My question is:
Do I still need to connect the white, red, and yellow audio and video from the DISH and DVD recorder to the receiver, or can I just go from the DVD recorder and DISH directly to the TV via composite video or S-video connections?
Confusing?
  • GorillaBoze Dec 28, 2007
    Here is what I have done so far.
    S-Video from DISH box to DVD recorder. Component Video from DVD recorder to TV (picture seems to be good).
    Fiber Optic audio from DISH box to receiver (seems to work fine). The DVD recorder only has a Digital Coax connection. The receiver has a Digital Coax connection (marked for CD) and an optical connection (marked for DVD). Can I run a Digital Coax from DVD recorder to CD connection on receiver? I would have to turn the receiver to CD when I watch a DVD, but it should work shouldn't it?
You'll hurt nothing by trying. Enjoy the nice pix and sound
Posted on Dec 28, 2007
  • 833 Answers
Generally, you only need one 'full' set of connections. If you are using s-video, you'll still need audio red and white or fiber...not both. Fiber is better. Where are you going to get your audio from? That's where you'll want to direct your feed. Some people cheat and run the red/white to the TV when they're too lazy to turn on the receiver! Mute it if it annoys you.
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
Apr 18, 2013 | Philips Magnavox MWR10D6 DVD Recorder
I HAVE DISH NETWORK AND WANT TO CONNECT MY NEW ZV427MG9 A UP TO RECORD A SHOW, ON DVD. MY TV HAS RCA CONECTIONS IN THE FRONT, BUT I HAVE TO BE ON VIDO 4 TO USE THOSE. MY DISH BOX HAS A SET IN THE BACK, I...
you need to hook the dvd recorder up to the dish net work, yellow to yellow port, red to red port, and white to white port.
the dvd recorder should have had a book in with it to show you how to hook it up
Mar 03, 2011 | Philips Magnavox DVD+R/+RW Recorder/VCR
Xbox and dish network problem
if you have like a dvd player then try hooking the xbox up to it in the front where the video is for the 3 plugs then try to plug dish network in the back of the dvd where the ant in plug is at then take the cord from the dvd player and plug it in the back of the tv if this dont work let me know
Aug 08, 2009 | Microsoft Xbox 360 Console
Connecting protron dvd to dish TV
I hope you have at least 2 sets of RCA jacks for (1) the Dish receiver and (2) the DVD player. Run 2 sets of R/W/Y cables to the TV. Done. Or use S-video for a better picture instead of yellow.
If you only have one composite input on TV (possible) then either buy a 2-way or more switch for the composite signal (R=right sound W=left Y=composite or S-video instead of composite) or you can instead pass the signal through the DVD recorder on the RCAs but the DVD will be on whenever anything is on. I assume you do not have a Dish 111 with only RF output but the same could be done for just the wimpy RF, just different switch. So there will be 3 RCA cables from Dish to a recorder and 3 then to the TV. Since you do not have a recorder, then go back to the switch or find another TV input.
Ten years, hum, you may not have had composite/S-video inputs and would have to use RF only--you did not say what TV was.
-Ken
Jul 19, 2009 | Protron PD-800 DVD Player
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Mar 04, 2008 | LG 42LC2D 42 in. LCD HDTV
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Yamaha HTR-5730 Receiver Logo
113 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
