Question about HP FAX 1250 Fax Machine (Black)
HP 1250 fax machine
Machine does not recieve faxes. It does not answer these calls.
  • LeBit Feb 26, 2008
    Hi;
    We too have the somewhat of the same problem, the difference is that we can receive incoming faxes but have to be home to receive them and this was the purpose of buying a new fax machine. The machine is set to Automatic and still can't receive without being home. We need/want not to be home to receive incoming faxes. As far as the steps taken, we have followed all the instructions and still aren't coming in without us home. It doesn't store in the memory to retrieve later either.
    MMA
    Problem Solver:
  • 9 Answers
Check if your fax machine is in Fax Mode or Auto-Fax.
Posted on Dec 30, 2007
Why does my HP 1250 Fax print blank pages?
Resset you setting to a Defoult, or Resset and restart your device.
Oct 06, 2014 | HP FAX 1250 Fax Machine (Black)
Is it possible to override or cancel the
No, you need to replace all ink carts with Genuine HP carts to get a sucessful alignment.
Jan 20, 2010 | HP FAX 1250 Fax Machine (Black)
Hp printer 6313 all in have problem for fax. error number 351
The machine has a ECM (Error Correction)error.
Could be:
  1. The remote machine has failed to respond.
  2. The remote user has oressed the Stop button.
  3. Incompatability between two machines may cause the remote machine to abandon the call.
Try turning off ECM in the Fax Settings Menu.
Nov 24, 2009 | HP FAX 1250 Fax Machine (Black)
When I try to send a fax I must dial 5 then number, do I have to put the area code if it's the same? and it says dialing then no answer. Does this mean it is actually trying to send the fax? (military)
It never hurts to use the area code in some places it is necessary.
No answer either means you are dialing a number that isn't a fax or the fax you are dialing is not set up to auto answer.
Try a fax you know is working.
DickyO
Oct 20, 2009 | HP FAX 1250 Fax Machine (Black)
Hp 640 cant send or receive fax(NO ANSWER FROM REMOTE FAX
Since the fax machine is about 4 weeks old, why not give it back to HP? Warranty still covers it.
May 22, 2009 | Office Equipment & Supplies
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
NOT RECEIVING FAXES OR INCOMING CALLS
Unplug for 10 seconds. Set to AUTO ANSWER
Oct 09, 2008 | HP FAX 1250 Fax Machine (Black)
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
HP FAX 1250 Fax Machine (Black) Logo
106 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
