Question about Hitachi P50H401 50 in. Plasma HDTV
Hitachi P50H4011 I am unable to get a picture using any of the three HDMI ports and am using composite cables on Input 2 instead. I have tried three different cables and different sources ie Denon DVD, and Bell satellite receiver. Any advice would be welcome
  • miaattitude Dec 30, 2007
    I have the same problem, everything was working fine ans all of sudden none of the hdmi ports are working. I've even upgrade de firmware but i`m still unable to connect any of my hdmi devices. Does anybody know what to do?
  • Anonymous Jan 01, 2008
    I have hooked up all three hdmi ports from the cablebox and none works. The cable company said was the tv and the saleman said he thought it was in the cable box. Does anyone know for sure and can it be fixed ????
  • 29 Answers
You need configurate the DVD nad the salellite receiver output to turn on the HDMI out.
Posted on Dec 28, 2007
Do you get better quality when inserting a composite cable into a component port?
NO the are 2 different type signals Composite is Three cables, each with RCA plugs at both ends, are often used to carry YPbPr analog component video. Componet is right and left audio and yellow is video.
Mar 01, 2018 | Televison & Video
Hitachi le55a6r9a sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board . In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
Jan 23, 2017 | Hitachi Televison & Video
Hdmi ports not working
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
5 Hdmi ports
Port one, cable box
port two, blue ray player
port three, Boxee box
port four, XBox 360
For example
Aug 07, 2012 | Hitachi 55HDT79 55 in. Plasma HDTV
I am trying to hook my ps3 up to my Hitachi 65 s500. I have the hdmi cable to hook up to imput 1 but when I do that The screen is showing fuzzy color but no picture. What am I doing wrong.
Make sure you're hooking it up to the HDMI port or the Composite port correctly. There is a red green and blue for composite that usually wont work in a port marked "Input 1" You would need to put it in "component/composite 1" correctly. I've come across this not working in 1080, but fine in 720p.
Jun 07, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
I have a hitachi p50h401 and sound went out. someone said update software how do you do that? Thank You
well if the sound went out it may have only effected 1 output source, What type source are you using, HDMI, RCA, Composite, DVI, VGA with mini adapter? If for example the HDMI, port you are using has simply lost sound to that port, HDMI carries both sound and video so simply moving to HDMI 2 or even 3 may solve this issue. Also i would suspect the cable you are using, HDMI cables are often defective. If you are using coax thru your cable company i would also change that coax from your tv to the hd box.
May 28, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I just bought Panasonic SC-PT480P-K DVD home theater and TC-P46ST30 TV. I connect DVD HDMI output to TV HDMI input port #1. But when I try to play DVD, I just got sound out to the home theater speakers...
Let us take things step by step.
1) If you have an AV cable ( Yellow /Red/White ) try connecting the DVD players composite out (Y/R/W) to the TV's composite in. Select AV input instead of HDMI on the TV and see if you are getting an image. This is to confirm that the DVD video circuit is OK.
2) If all is OK in step one you can try buying a good HDMI v1.3 cable. You do not need a v1.4 cable which is only good for 3D bluray players.
Revert back for more.
Mar 07, 2011 | Panasonic SCPT480 Theater System
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
Dec 15, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
How can i watch movies from computer to my tv
You probably need to get a composite video output card for your computer. Actually, I've seen many cards that have both a composite video output AND a DVI output port on 1 card. The DVI output will give you a noticeably sharper picture than composite video, but you need to check if your TV has a DVI or HDMI input. (If it was manufactured after 2000, it probably does.) If you TV was manufactured after 2006, it probably has 1 or more HDMI inputs instead of DVI. You can buy a DVI to HDMI converter cable. That takes care of the picture; to get sound to the TV, you will need to connect separate sound cables to your TV. Your computer needs to have a line-level output jack on it's sound card, and you will need to get an adapter cable (from Radio Shack) to convert the stereo mini-plug to 2 RCA type plugs to plug into your TV. And that should do it!
Dec 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Hitachi P50H401 50 in. Plasma HDTV Logo
307 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
