RIGHT STRUT ( SHOCK ) BROKEN AT DRUM. HOW DO I REPLACE SHOCK ?
HOW DO I GET THE PINS OUT? AND HOW TO I RE-INSTALL NEW SHOCK TO DRUM?
THANKS ALLOT FOR SUPPORT !!
Comments:
Dec 29, 2007
- Hey Sagacious !
Thanks very much for the support! I hope I can "pass it forward"
to someone looking for support in my trade.
It's people like you that make this a better place.
Thanks again !!
-   Both of the shocks on mine are broken, but they both appear to bolted in at the top with a plastic bolt... is this possible or am I crazy?-   YoTeach
Mar 29, 2009
-   The washer became extremely unbalanced and the left spring and shock broke off, maybe some plastic too. Is this something a novice can order parts for and fix or should I call in a pro?
-   wrussell3
There was a revision to the shocks which you'll see when you get the new ones. Squeeze the two retaining barbs in with a pair of pliers then twist and push rearward. On the right one you have the air dome in the way - it helps to have a buddy pull from the back while you release the barbs.
Was this helpful?
Yes
No
Popular Solutions for GE WPXH214A Front Load Washer
I have a w10117769a and the I have clothes in the washer that completed it's cycle of cleaning and...
(More)
I have a w10117769a and the I have clothes in the washer that completed it's cycle of cleaning and the door will not open. The manual said to press the stop button to open which I tried and the add garment light came on. I tried starting and stopping the machine with no luck. The machine is stuck and will not unlock the door
