convergence vertical red line is jagged on upper section off straight line when trying to adjust. Tried dvd from inputs, scrambled to sound.Is this a covergence repair.
If you go into the customer menu and select convergence and either red or blue will not move in some direction---up and down or left and right--It is a Convergence problem.
I have repaired hundreds of these sets with this type of trouble---it depends on if you have some level of skill at soldering etc---This set uses 2 Convergence chips and both along with any of the protect resistors around them that are bad would have to be replaced.
Check the set in the convergence mode and if you see what I have described let me know---If you can do the repair--I can tell you the best place to get the parts and also what exactly else to look for bad.
If you cannot do this yourself, I have options I can suggest for you---least expensive way is if you can do it yourself---This kind of repair is very common in all rear projection sets--I did 2 today here where I live--about one hour start to finish in someones home.
After it is repaired--it will not have the same problem again for 5-8 years---lifespan of the two chips.
I am here to help---let me know what you find and I am willing to assist you.
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hitachi 53FDX01B 53 in. Rear
I have a 53fdx01ba.The reds would shift erratically and bumping the tv would temp fix problem. After...
(More)
I have a 53fdx01ba.The reds would shift erratically and bumping the tv would temp fix problem. After reading posts, I started wiggling components around the convergence ics and found i must have a weak / broken solder joint. tweeked some adjustments to make the picture better and decided to resolder the chips over the holidays. about a week later the picture and sound went out. I did notice lp13 is hot and is making a ticking sound.
Picture is breaking up. You can see yellow and blue seperate. It seems as if the picture has lost...
(More)
Picture is breaking up. You can see yellow and blue seperate. It seems as if the picture has lost the sync.
