Hello there: This a common problem for all front loaders. Your washer will not drain
or work 'cause your outlet filter is clogged. Usually this small door
is on the left side front below of your washer. Expect some water to
come out when you open the door, etc. Clean out your filter and
refit.....things should be fine. ok I hope that his helps out best regards michael
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for LG WM2277H Front Load Washer
I would like to remove and clean around the front door seal of my LG WM2277HS front load washer and...
(More)
I would like to remove and clean around the front door seal of my LG WM2277HS front load washer and although it doesn't look that complicated, I'm sure it's not as easy as it looks (nothing ever is). I was looking for a parts list for the machine which usually shows an exploded view but no such luck. Can anyone provide guidance on this? Thanks, Dennis
I am getting a weird Error code. It looks like a small "b" and a "E", but the...
(More)
I am getting a weird Error code. It looks like a small "b" and a "E", but the small b doesn't have the right side of the letter. Some what looks like a upside down F.
