Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Problem for Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
By djz1066 on Oct 17, 2009
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher drains fine, but low pressure & noisy main pump during wash. Pipes aren't soiled. Suspect main motor ;how do I remove/replace this?
Comments:
Oct 18, 2009
- Well, several hours and gross, painstaking dis- assembly later, I found the problem: the impeller in the main circulation pump had broken free of the drive plate connected to the motor. The scuffing noise I heard was the impeller plate spinning lethargically against the inside of the pump housing. The impeller should have been connected by a series of what I assume to be shear pins - some of which would have been tight fit or heat molded on the other side, and some of them simple loose, locator fit - intended to allow the motor to spin in the event of a dinosaur bone or something lodging in the impeller. Naturally there is no sign of any such foreign body, and the pins looked like they simply gave up, as only some of them are broken - the majority are fine. The pump and everything else are fine. I'm irritated now, because I'm probably going to have to buy an entire pump or worse for the sake of a 90 cent part. Maybe I can epoxy the impeller back on with a couple of the remaining pins.
Popular Solutions for Bosch 24 in. SHU66C02 /
Questions and Unsolved Problems for Bosch 24 in. SHU66C02 /
Do you recommend Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher?
Answer
Answer
dishwasher continuously trys to drain do not know if if is getting water
Answer
Items on the bottom rack are not being cleaned properly - this problem started about 2 weeks ago and... (More)
Answer
Base plates, I have 3 black parts on a used Bosch dishwasher, 1 curved, one rubber part that slips... (More)
Answer
build up of calcium clean your hoses check your lines they maybe blocked sound like a high pitch... (More)
Answer
My Bosch Logixx dishwasher makes a banging noise when it starts the cycle and again half way... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , CA
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
